Oil Pressure Woes
Old 04-29-2013, 08:49 AM
Travis99Ram's Avatar
Travis99Ram
Travis99Ram is offline
Default Oil Pressure Woes
Ok so I had the problem of my oil pressure gauge dropping whenever the rpm's would drop and would rise when I accelerated again. Through search of other threads I found the culprit was the oil pressure sending unit...so I replaced but I still ave the problem, just not as often and the oil pressure will rebound on its own without me giving it gas, also the needle will bounce around a bit...what else could be giving me this problem taking into consideration that the sending unit it new?
Old 04-29-2013, 09:27 AM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Stick a mechanical gauge on it.
Do you hear any ticking?
Old 04-29-2013, 10:10 AM
Arde's Avatar
Arde
Arde is offline
+1 on the mechanical gauge, the OEM oil pressure gauges on these Dodges are worthless.
Old 04-29-2013, 10:21 AM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
Another +1 for the mechanical gauge.
It could also be as simple as having the oil pickup junked up.
Old 05-05-2013, 05:46 PM
Travis99Ram
Okay, so I put a mechanical oil gauge in and at first the pressure was reading fine about 40 psi, then it dropped to just below 20. And wont rise unless I give it some gas then drop again once I let off. The motor has enough oil in it. So where do I go from here?
Old 05-05-2013, 05:58 PM
Travis99Ram
Ticking from where? The new mechanical gauge?
Old 05-05-2013, 06:30 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
miles on engine?
to squeeze more life from the engine, drop the oil pan and replace the oil pump with a new "high volume" pump. also clean or replace oil pickup tube. if the rear main seal is leaking, replace it too.
http://www.pavementsucks.com/tech-article-31.html
Old 05-05-2013, 06:48 PM
Travis99Ram
Originally Posted by dhvaughan
miles on engine?
The engine has 147k on it. Ok, so a new oil pump is on the agenda, thanks for the help.
Old 05-05-2013, 09:51 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
lifter ticking
your pick up tube could be clogged as stated earlier
Old 05-05-2013, 09:58 PM
Travis99Ram
lifter ticking
I don't hear any lifters tapping.
Quick Reply: Oil Pressure Woes
