2nd Gen Durango 2004 - 2009
Durango with P0456 code
Old 04-25-2013, 12:33 PM
john.bonet's Avatar
john.bonet
john.bonet is offline
Default Durango with P0456 code
I been having the CEL come on several times a month with the P0456 code. So far I have replace Purge valve, leak detection pump, vac hoses, fuel pump and gas cap. Now the code comes every 4 to 5 days before was every 10 to 12 days. What i do now?
Old 04-26-2013, 08:51 AM
john.bonet's Avatar
john.bonet
Default ANY Help
Can anyone tell me anything about it, where to look next? Something.
Old 04-26-2013, 09:31 AM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Old 05-10-2013, 09:38 PM
john.bonet's Avatar
john.bonet
It has been 2 weeks and no response.
Old 05-11-2013, 07:34 AM
1969CoronetR/T
vaffanculo
Does your gas purge out of the tank after filling it up? Does your charcoal canister purge and streak your quarter panel below the fuel door?
FF
Old 05-13-2013, 12:33 PM
john.bonet's Avatar
john.bonet
On May 1st I removed the charcoal canister and leak detection pump. I found the leak detection pump upper half disconnected from the body, I took it apart cleaned the dust off rinse the diaphragm and put back together. So far CEL has not come back, but since I replaced the gas pump it spills gas out the fill tube if I pump gas too fast.
Old 05-14-2013, 12:57 PM
1969CoronetR/T
vaffanculo
There is a recall on the vent tube and tank for most if not all Durango's. Call a dealer with your VIN.
FF
Old 05-14-2013, 02:45 PM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
Many 2005-06 models had a lifetime warranty extension on the inlet check valve. If you want me to check if your vehicle is covered under this PM me your vin. See below.
NUMBER: 14-002-13 REV. A
GROUP: Fuel System
DATE: March 13, 2013
SUBJECT:
Fuel Spit Back During Refueling Due To Inlet Check Valve (X48 Lifetime Warranty
Extension)
OVERVIEW:
This bulletin involves replacing the fuel filler tube if the condition occurs.
NOTE: When removing the existing fuel filler tube note how it comes out to aid in
installation of the new part.
MODELS:
2005 - 2006 (HB) Durango
NOTE: This Extended Warranty Bulletin applies to vehicles equipped with a gasoline
engine built between December 1, 2004 (MDH 1201XX) and January 31, 2006
(MDH0131XX).
SYMPTOM/CONDITION:
Some customers may experience a fuel spit back condition during a refueling event.
Old 05-15-2013, 09:03 AM
john.bonet's Avatar
john.bonet
Thanks for the help. I gave the info to Dodge Cares. So far the CEL hasn't come back which is a good thing. Good looking out on the fuel spit back recall. Thanks all for the help.
Old 05-15-2013, 09:12 AM
DodgeCares's Avatar
DodgeCares
Please keep in mind this was a warranty extension, not a recall.
Quick Reply: Durango with P0456 code
