OK my ram when u turn the key to the on position everything comes on properly the fuel pump primes but when u try to crank it clicks 1 time and then goes dead nothing will do anything until you disconnect both battery terminals then it does the same thing
You need to post your question in the 2nd gen Ram tech section. Those guys can help you out. This section is for posting pics and showing off your ride.
