Wet and Loose Starter
Old 04-19-2013, 12:51 AM
TheBigRedTruck's Avatar
TheBigRedTruck
TheBigRedTruck is offline
Default Wet and Loose Starter
My truck has been acting up lately. Occasionally it will try to start, and without even cranking, I'll hear a loud "snap"/"spark" and the truck will act as if the battery is disconnected. I then have to remove the battery cables and put them back on. I figured out the problem wasn't the fuse box so I took a look at my starter (for the first time). I noticed I was able to move it back and forth on the one bolt that was holding it on. The shaft that has the gear on it was soaked in oil/transmission fluid. Could this be shorting out my capacitor?
Old 04-19-2013, 06:46 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
"capacitor" ? You mean starter solenoid?(or armature maybe) You have some problems to fix I'm thinking. And yes, the starter for one. And the tranny oil leak. ? Thats the front pump/tc seal . Tranny removal time.
Old 04-19-2013, 07:35 PM
TheBigRedTruck
just installed a new starter and all is good.
Old 04-19-2013, 07:55 PM
zman17's Avatar
zman17
zman17 is offline
With 2 bolts I hope. And you still have the tranny fluid issue, which replacing the starter won't help with.
Old 04-19-2013, 08:07 PM
TheBigRedTruck
the starter i got makes it impossible to put the top bolt in. so i put a smaller bolt and a nut on. the starter wont budge now. ill worry about the tranny when i get a manual 5speed lol
Quick Reply: Wet and Loose Starter
