Gas tank size
Old 04-15-2013, 08:12 PM
funair02's Avatar
funair02
funair02 is offline
Default Gas tank size
Hi all...
What size should my 2002 3.9 1500 gas tank be?
I can only get 20-24 gallons in...Everywhere I read it is 31.
The gauge reads accurately too. I havent tried to run it dry though.
Old 04-15-2013, 11:13 PM
Rusty93RamVan's Avatar
Rusty93RamVan
Rusty93RamVan is offline
Sounds like your tank float is not properly adjusted. After you fill up how many miles can you drive before the fuel gauge needle moves off the "F" mark? If it's more than about 75 I would say time to adjust the float arm or replace the fuel level sender.
You could run the tank dry and then see how much it takes to refill -- just make sure to carry a 5 gallon jug of fuel with you so you're not calling AAA for roadside assistance. Then run to the gas station and fill up, add in the five gallons from the jug into the equation and see what number you get. For your van I believe it should be 32 gallons.
Old 04-16-2013, 08:49 AM
funair02's Avatar
funair02
funair02 is offline
It starts to move at about 50. At the 3/4 mark I have already gone 100-130 miles. At 1/2 I am usually way over 220...
I guess I will have to run it and see what happens...
Quick Reply: Gas tank size
