3rd Gen Durango 2011+ models
Old 08-06-2015, 01:21 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
How do I remove the outer rear tail lamp
Old 03-31-2013, 04:49 PM
happyfirst's Avatar
happyfirst
happyfirst is offline
Default How do I remove the outer rear tail lamp
One of the bulbs blew. I need to remove the outer most rear tail light, the one on the quarter panel. With the liftgate open I see two push pins there that I removed, but something is still holding it in.
I found this post https://dodgeforum.com/forum/3rd-gen...go-2012-a.html .
It would be nice if there was more detail for outer step #2. Locate where?
Do I need to completely or only partial remove the inside panel? If so, where do I start prying first? Are there any screws that need to be removed on the inside first or do I just start pulling or prying?
Old 03-31-2013, 05:40 PM
FSTDANGO3's Avatar
FSTDANGO3
FSTDANGO3 is offline
I thought it was just the 2 push pins and then tilt it to the outside. I thought it had a tab on it that locked into quarter panel
STEVE
Old 03-31-2013, 09:20 PM
CMil527's Avatar
CMil527
CMil527 is offline
Just 2 push pins and then pull towards the rear they simply snug in place!
Old 04-01-2013, 07:09 AM
baum's Avatar
baum
baum is offline
HAHA everyones bulbs must be going out at the same time... i just did this also.
like stated just pull!! there are to pressure clips in the forward most (towards the front of the car) that are a b*tch to get to release.
Old 04-01-2013, 07:30 AM
FSTDANGO3's Avatar
FSTDANGO3
Funny I noticed a lot of Jeep Cherokees riding around with 1 headlight as well, always the passenger side!
Old 04-01-2013, 07:20 PM
///AMG Hauler's Avatar
///AMG Hauler
///AMG Hauler is offline
Just replaced a turn signal bulb last week.
Old 04-02-2013, 08:30 AM
NUTTS12CREW's Avatar
NUTTS12CREW
NUTTS12CREW is offline
Wait until you have the pleasure of the ones on the lift gate! I just had my passenger side go out, so while I had it apart, I replaced both sides with LED's. Hopefully they last a long time.
Old 04-02-2013, 08:53 AM
FSTDANGO3's Avatar
FSTDANGO3
Please tell us which bulbs you used...
Old 04-02-2013, 09:23 AM
baum's Avatar
baum
baum is offline
hahaha i just did these also!! first it was the turn/ brake light, then i had these out also. problem with these is the vehicle doesnt tell you like it does with the others
Old 04-02-2013, 11:50 AM
NUTTS12CREW
Honestly, they were the direct replacement bulbs Autozone had when I was there getting a code read. I got the 4 LED Red set and they look a darker red than the OEM, but also brighter. I am replaceng the outer tails next. They also had a 10 or 12 LED red for those. Best part was I think they were $12 for the 4 of them. I'll see if I can find the package and post the brand.
Quick Reply: How do I remove the outer rear tail lamp
