2009 ram dash removal
Old 03-20-2013, 09:05 PM
bxsnipe's Avatar
bxsnipe
bxsnipe is offline
Question 2009 ram dash removal
I recently purchased a Lockpick and want to install it myself I saw a utube clip that showed the removal on a 2009 Ram dash but mine has bucket seats and it seems that the trim around the shift lever has to be removed I can't seem to remove the chrome bezel around the gear shift I am afraid if I try to force it I will break it. It appears to be loose all around except for two places. Any help would be appreciated.
Old 03-23-2013, 10:01 AM
oldjeep's Avatar
oldjeep
oldjeep is offline
The FSM makes it sounds like it just pops off:
2.Using trim stick C-4755 or equivalent, remove shift bezel trim ring (1) and the shift cable cover (2).
Old 06-12-2013, 11:13 AM
SolarPLEX's Avatar
SolarPLEX
SolarPLEX is offline
use a butter knife or something thin and work your way around it and pry gently. it has tabs that have ribs that friction lock. If you break it no big deal, i took mine out and put it back on and it dosent fit as tight.
Old 06-12-2013, 04:09 PM
War Horse's Avatar
War Horse
War Horse is offline
I used a fingernail file on mine when I installed the Mopar iPod connector. Just take it slow and pry a little at a time. Do it evenly and it'll pop right out. While out, you could also use the time to sand and paint it. I did mine and painted it matte black. Best mod ever. It seemed like the sun was always bouncing off it into my eyes. Death to the Bling Ring!
Quick Reply: 2009 ram dash removal
