Bypass the Heater Core
Old 03-09-2013, 09:28 PM
rob497's Avatar
rob497
rob497 is offline
Default Bypass the Heater Core
My heater core went yesterday (during snow storm) and I got a nice wet inner windshield and a new air-freshener (antifreeze).
On my old truck, i just bypassed the core by cutting and connecting the 2 hoses in the engine compartment.
Is it possible to bypass the heater core in a 2000 Durango (4.7)?
Thanks
Old 03-09-2013, 09:48 PM
Old_School's Avatar
Old_School
Old_School is offline
You can as a temp solution but, i would advise to fix it ASAP as you will not have heat or defog/defrost.
Old 03-10-2013, 09:20 PM
FSTDANGO3's Avatar
FSTDANGO3
FSTDANGO3 is offline
You can bypass it right at firewall area. If you have rear heat you can still use rear heat to warm your D
Old 06-02-2013, 11:04 AM
mikul515's Avatar
mikul515
mikul515 is offline
my heater core went a few weeks ago, now i have this vapor coming in through every space on my dash.(also smells antifreeze)..someone did tell me i can plug the line so the antifreeze dosent get the the h.c. , and continue to leak... is this a good temporary solution?, also ,...since the summer is just about here, will this affect my air conditioner??
Old 06-02-2013, 11:29 AM
Old_School's Avatar
Old_School
You could take the two hoses off the heater core at the firewall in the engine bay and join the two hoses together then it will just flow like the heater core is there and you would not have to worry about any crap getting into or coming out of the system. Doing this is perfectly fine, you will just loose your heat/defrost but, being that its June i don't think that will bother you much.
As for you A/C i won't hurt it a bit, in fact it might work a little better since there is not the added heat in the cabin from the heater core. I personally have a brass valve on the in line of my heater core that way in the summer i can shut it off for that very reason.
Old 06-04-2013, 05:06 PM
cmikolajczyk's Avatar
cmikolajczyk
cmikolajczyk is offline
As said above, it should not have any negative effects except loss of defrost and heat from dash.
Old 06-06-2013, 05:48 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
well loss of hot defrost, you can still blow air on the windshield if you should need it.
Quick Reply: Bypass the Heater Core
