Ignition Fuse Keeps Blowing ???
Old 03-03-2013, 05:24 PM
farmerd32548's Avatar
farmerd32548
farmerd32548 is offline
Thumbs down Ignition Fuse Keeps Blowing ???
Ihave a 98 Dodge Dakota that keeps blowing the main Ignition fuse when the keyis turned to the on/run or start positions. I have looked for shorts and done some testing but cannot find the problem. Is this a common or recurring problem?If you have encountered this please reply.
Old 03-03-2013, 06:12 PM
rott96's Avatar
rott96
rott96 is offline
Is there any obvious water stains? In know the rubber weather strip back by the cowl have a tendency to go bad....had to change mine....was getting water in the fuse box under the Hood...
Old 03-03-2013, 11:42 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Possibly a bad ignition switch.
I will move this to the 2nd generation Dakota sub-forum.
Old 09-07-2022, 11:12 PM
jetski's Avatar
jetski
jetski is offline
[QUOTE=farmerd32548;2975913]Ihave a 98 Dodge Dakota that keeps blowing the main Ignition fuse when the keyis turned to the on/run or start positions. I have looked for shorts and done some testing but cannot find the problem. Is this a common or recurring problem?If you have encountered this please reply.[/QUOT……Where your Fuse Located?
Quick Reply: Ignition Fuse Keeps Blowing ???
