redneck_rams 360 build thread
Old 01-24-2013, 02:46 PM
redneck_ram's Avatar
redneck_ram
redneck_ram is offline
Default redneck_rams 360 build thread
well, going to be camming my truck. let me hear your thoughts on cam style for low end grunt, with some good lopey sound.
Old 01-24-2013, 02:53 PM
You won't get a bumpy idle with a cam designed for low-end.
Look for something with an operating range from idle, to 5K. They are out there. Won't be an absolute powerhouse on the freeway, but, for towing/plowing, you will definitely like it.
Old 01-24-2013, 03:14 PM
redneck_ram
ok, so i found these 5 cams, theyre all within the same range of each other... my 318 has flat top pistons, so which of these could i get away with running the 1.7's with? extremely new to the internal motor world. havent touched any of that stuff before.
what do yall think?
http://www.summitracing.com/parts/cca-20-744-9
http://www.summitracing.com/parts/crn-704121
http://www.summitracing.com/parts/cca-20-608-9
http://www.summitracing.com/parts/cro-34418
http://www.summitracing.com/parts/crn-704111
Old 01-24-2013, 03:17 PM
FireDodge's Avatar
FireDodge
FireDodge is offline
Aren't you getting the odessa EQ heads? I think those come with springs good up to .515, so the 4th one would need bigger springs.
Old 01-24-2013, 03:18 PM
redneck_ram
no im not getting the eq heads, im getting factory replacements from odessa, and will install better springs if needed.
Old 01-24-2013, 03:26 PM
FireDodge's Avatar
FireDodge
Oh I gotcha. Then I retract my statement
Old 01-24-2013, 06:03 PM
renardk764's Avatar
renardk764
renardk764 is offline
I'm thinking about this one with EQ monster heads and 1.6 rockers. Thoughts?
Camshaft Technical Details
Intake Valve Lift 1.5 .480
Exhaust Valve Lift 1.5 .487"
Intake Valve Lift 1.6 .512"
Exhaust Valve Lift 1.6 .520"
Intake Duration at .050" 208°
Exhaust Duration at .050" 214°
Lobe Separation Angle 114º
Intake Centerline 111º
Intake Opening at .050" -7° BTC
Exhaust Opening at .050" 44° BBC
Intake Closing at .050" 35° ABC
Exhaust Closing at .050" -10° ATC
Min. Suggested Cylinder PSI 165
Sweet Spot RPM Idle - 5500
Old 01-24-2013, 06:11 PM
redneck_ram
what motor do you have? you may run into valve to piston clearance with those 2.02 valves
Old 01-24-2013, 06:19 PM
renardk764's Avatar
renardk764
318. Truck has 255000+ on it so a bottom end freshing is needed soon. Rings, pistons etc.
Old 01-24-2013, 06:41 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
have you done a compression test? if you get anything over 100 psi you are good. if you want more compression could could try filling the cylinders with gas. i can't say for sure but i think that is why i see 150+psi on all the cylinders in my 81. when i first got it the engine would literally flood with gas to the point the starter could not turn the engine over. i am guessing at the same time it removed all the carbon and crap from the rings and allowed the rings to seal better. just had to do lots of oil changes after.
Quick Reply: redneck_rams 360 build thread
