2000 Valve Cover gormment for the bolts????
Old 01-13-2013, 03:32 PM
armaniEfiftyfive's Avatar
armaniEfiftyfive
armaniEfiftyfive is offline
Exclamation 2000 Valve Cover gormment for the bolts????
Where can I buy this? My mechanic friend stopped by and said I should really replace the bolt gormment to the valve cover as this is where it would also leak. But I haven't had any luck on finding it a local pep boys, advanced our autozone.
Anyone?
2000 Dodge Status
2.4
Old 01-13-2013, 03:49 PM
armaniEfiftyfive
Bolt attached.
Anyone?
2000 Dodge Status
2.4
Old 01-13-2013, 05:46 PM
BillS's Avatar
BillS
BillS is offline
most likely have to go to dealer to find it,you might check home depot, lowes,or tractor supply if you have one(some have good selections of grommets,washers etc.)
Old 01-14-2013, 12:30 AM
armaniEfiftyfive
Hmm... ok do you really think I need to change them? They kinda look good to me.
I would just hate to repeat the job. Right now it's taken apart and waiting for me to get the grommets. (winter car) and a great low maintenance car. DD is a (E55)
Old 01-15-2013, 12:09 PM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Looking at the parts manual online it looks like you have to purchase new bolts and the gromet comes with, $1.89 each
Old 01-17-2013, 08:13 PM
armaniEfiftyfive
Thank you. I checked the bolts after putting it all together and it doesn't appear to be leaking through the inner bolts. Ill keep an eye on it. If not no biggie Ill grab the bolts at the dealer.
Car has been really reliable in the New England winter months. Purrs like kitten with the new plugs.
140k and going strong.
Quick Reply: 2000 Valve Cover gormment for the bolts????
