will my heater still work
Old 12-12-2012, 03:20 PM
seansmink's Avatar
seansmink
seansmink is offline
Default will my heater still work
Hello my name is sean. i have a 2003 dodge durango 2w drive 5.9l v8. when i turn my ac on the compressor makes a ticking sound. what could this be, it blows cold and my second question is can i run my heater even if ac does not work
Old 12-12-2012, 05:30 PM
seansmink's Avatar
seansmink
so my heater works in the front only. the second and third row just blow cold air. what can i do to fix this??? please help gooing on road trip on 22 of dec to maryland and i wanna make sure my wife and baby are safe and warm.
Old 12-12-2012, 05:59 PM
Old_School's Avatar
Old_School
Old_School is offline
Sounds like your rear heater core is plugged or a blend door issue.. most likely if its the heater core you will have to replace that for it to work again... as for the compressor you heat should work without the a/c in order... mine does and my a/c has been out of service since september.
Old 12-12-2012, 09:14 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
you can definitely run the heater w/o the a/c working, i actually have my a/c clutch bypassed for the winter (ok i put in a bypass switch) but same idea as not having a/c
Old 12-12-2012, 11:02 PM
70Cuda4Speed's Avatar
70Cuda4Speed
70Cuda4Speed is offline
Sounds kind of like a Blend-Door issue. Check this thread: https://dodgeforum.com/forum/1st-gen...orks-fine.html
The way the HVAC works, is that the heater core always has full hot water flow through it. The blend door directs air either through the hot heater core or through the ac evaporator coil, or mixes some of both, to get the temperature you select with the control ****. Sounds like your blend door broke and is probably resting down on top of the heater core, preventing any air from flowing through it (so air just bypasses the core).
Old 12-12-2012, 11:36 PM
krupaeric's Avatar
krupaeric
krupaeric is offline
no clue on the rear heat issue, but i have my ac completely removed from my d, no bypass pulley, just found a shorter belt. and my d heats up nice and quickly.
Quick Reply: will my heater still work
