2001 dodge ram 2500 v10
Old 11-07-2012, 11:51 AM
Rip_jeff's Avatar
Rip_jeff
Rip_jeff is offline
Default 2001 dodge ram 2500 v10
Does anyone know why the parts stores aren't showing a oil pump at all ?
Old 11-07-2012, 03:18 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Because as far as I know it's not a pump on a v10 so to speak, like on a v8. The oil pump is built into the timing cover and you buy a kit to fix it. Maybe dealer only at this point.
Old 11-07-2012, 04:31 PM
Jimythefan's Avatar
Jimythefan
Jimythefan is offline
Zman is right. The oil pump is a couple of rotors inside the timing chain cover that go around the end of the crank. They need to be removed and measured for clearance.
Old 11-07-2012, 08:12 PM
VEETEN's Avatar
VEETEN
VEETEN is offline
Better yet why do the parts stores not show a 2001 quad cab with the V10 motor?
Back on topic...... What Zman said sounds like the reason.
Old 11-08-2012, 06:35 AM
Rip_jeff's Avatar
Rip_jeff
Rip_jeff is offline
Gonna check that out today. Maybe there work or not torqued. You happen to have a pic ?
Old 11-08-2012, 06:53 AM
Rip_jeff's Avatar
Rip_jeff
Rip_jeff is offline
Or do you know the specific name of the parts
Old 11-08-2012, 01:51 PM
Jimythefan's Avatar
Jimythefan
Grab the 2001 parts and service manuals from the FAQ thread. They'll show you exactly where it's located, how to remove and measure them, and what the part numbers are.
Here's a blowup from the manual. #6 are the oil pump rotors.
Old 11-08-2012, 04:19 PM
Rip_jeff's Avatar
Rip_jeff
Rip_jeff is offline
Think I mighty just drive it to the woods and rip it apart with my .223
Old 11-08-2012, 05:06 PM
stewie01's Avatar
stewie01
stewie01 is offline
If you're gonna do that you might as well give the truck to me!
Old 11-08-2012, 05:18 PM
Jimythefan's Avatar
Jimythefan
It's a little work, but pulling the timing chain cover and servicing the oil pump isn't all that hard. Are you sure it's the pump and not another issue?
Quick Reply: 2001 dodge ram 2500 v10
