How to remove the valve body
Old 11-06-2012, 03:30 PM
cheapez's Avatar
cheapez
cheapez is offline
Default How to remove the valve body
My car is a 2005 Dodge Neon, 4 speeds automatic transmission (41TE).
I'm going to remove the valve body, and have a look inside.
I need tips on how to remove it.
Let me know how heavy that thing is. I don't want it to fall on me.
Old 11-06-2012, 06:34 PM
I_Ride_Neon's Avatar
I_Ride_Neon
I_Ride_Neon is offline
Why are you pulling the valve body? Its not heavy at all, seriously one hand on the valve body and pull the bolts. Have rags handy. I think those drain pans dont use gaskets, they use RTV. It may come with a gasket on it, but remove it and use black RTV.
Old 11-07-2012, 08:00 AM
cheapez's Avatar
cheapez
cheapez is offline
It has something to do with downshifted to 2nd gear:
- When I slowed the car down enough, it downshift to 2nd gear.
- If I step on the gas petal right away, car will gain some speed, and slam into 3rd gear (a very harsh shift) at around 25-30 mph.
- If I don't step on the gas petal right away. It shifts normal.
It shifts fine If I started from 1st gear.
Old 11-07-2012, 08:14 AM
cheapez's Avatar
cheapez
cheapez is offline
To remove the valve body, you just have to remove the bolts?
Someone tried to remove it but it stuck in there. He had to turned the manual valve lever clockwise or something.
The trans pan on my car has a gasket but it still leak some.
Is the black RTV like glue?
Old 11-07-2012, 08:20 AM
cheapez's Avatar
cheapez
cheapez is offline
I took the solenoid pack out, and disassembled it.
Nothing seem to be wrong with it, plus I don't think it's the solenoid pack that caused the problem.
My only option now is to remove the valve body.
Old 11-07-2012, 08:48 AM
I_Ride_Neon
So you have a bench tester and tested the solenoids and sensors? First I would check trans codes with a scanner. Black RTV gasket maker is not like glue. Its like a silicone gasket maker. Sounds like its an electrical issue, not an internal one. Check ball needs to go back where you find them so be sure you dont drop them.
Old 11-07-2012, 09:33 AM
cheapez's Avatar
cheapez
cheapez is offline
I don't get any error code, so this could be a mechanical issue.
I don't have a bench tester.
Usually when the solenoid/sensors go bad, it throws error codes.
The problem with the solenoid pack/sensors is usually with your car not shift into a gear, go to limp mode, delayed forward engagement, ...
The problem I'm having has something to do with my car downshifted to 2nd gear, and then shift back to 3rd. Could be problem with hydraulic pressure, or shift overlap. I can't figure out.
I could replace the solenoid pack, and sensors but I don't think they are causing problems for now.
Old 11-07-2012, 09:44 AM
cheapez's Avatar
cheapez
cheapez is offline
Thank you.
I will drop it slowly so the ***** won't fall out.
Old 11-07-2012, 01:19 PM
I_Ride_Neon
I still think its electrical. I think its the solenoid pack. They wont always throw codes, actually the last 4 I did on dodges had no codes at all. Need to have a good scanner to check tranny codes, some scanners wont show them. I would start by testing the solenoids.
Old 11-07-2012, 01:56 PM
cheapez's Avatar
cheapez
cheapez is offline
If you say so, I will find a way to test the solenoid.
If I can't test it, I will just replace it.
If the problem is fixed, then I won't have to remove the valve body. That will save me some time.
Thanks again.
Quick Reply: How to remove the valve body
