1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
Ignition control module
Old 10-27-2012, 03:40 PM
Howie1968's Avatar
Howie1968
Howie1968 is offline
Default Ignition control module
Hello, i am new to the forumn I have a 1990 d 150 with a 5.2 i love this old truck but im having an issue driving down the road sometimes it will die but will start right back up other times when driving it will cut out like it lost power then starts going again so far ive replaced fuel filter fuel lines fuel relay ive put new distribtor cap new wires new platinum plugs the mechanic put a new fuel injector they cant seem to find the problem says he thinks its in fuel delivery but no codes did somne serches and it says to check the ignition control module so i went and bought it but i cant find it anywhere in my engine also bought a new coil also which i will have the mechanic install can anyone tell me where the ignition control module is on my 1990 d 150 with a 5.2 automatic also some days it will run fine then some days ill be driving it will cut out then kick back in they say fule pressure is fine engine starts right up idles then every so often it will die is this the right ignition control module?
ignition control module i gpot from parts store
Old 10-27-2012, 06:30 PM
sls001's Avatar
sls001
sls001 is offline
You will not find that part under the hood of your truck. That is for a earlier model year.
The module on your truck is inside the distributor.
Did they happen to drive down the road with the fuel pressure gauge hooked up to see if just prior to it cutting out you lost pressure? You could have one or more of several known issues.
Bad grounds, poor connections, failing dizzy, etc. There was also a TSB from Dodge in those years detailing problems with the rubber fuel hose inside the tank becoming cracked and porous.
Old 10-27-2012, 06:33 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
and the guy behind the counter gave you that ignition control module for a 90 dodge ram? you need to take that back. it will not work with your truck unless someone has converted it to carb.
now i would guess your problem could possibly be a bad wire or something simple.
Old 10-27-2012, 06:53 PM
Howie1968's Avatar
Howie1968
thank you as i looked every where under the hood they said that was for my 90 ram mine is fuel injected has 2 injextors
Old 10-27-2012, 07:33 PM
SEAL's Avatar
SEAL
SEAL is offline
Actually the computer is your ignition control module and it is in the drivers side fender by the battery.
I would check for a problem in the TPS (Throttle Position Sensor). You may have a dead spot.
Old 10-27-2012, 07:59 PM
Howie1968's Avatar
Howie1968
where is the trottle position sensor?
Old 10-28-2012, 05:59 AM
SEAL's Avatar
SEAL
SEAL is offline
It is on the passengers side of the throttle body. It tells the computer what position the butterflies in the throttle body are at. It is nothing but a rheostat that changes resistance as it is turned.
Old 10-30-2012, 09:26 PM
SixGun's Avatar
SixGun
SixGun is offline
I tell you what, a service manual comes in real handy if you want to test the sensors on our trucks. That's what helped me out. That stuff was all greek to me. Worth every penny.
Quick Reply: Ignition control module
