Magnaflow Y-Pipe / CAT
Old 10-03-2012, 02:50 PM
Miguelito1961's Avatar
Miguelito1961
Miguelito1961 is offline
Default Magnaflow Y-Pipe / CAT
I've read that the Magnaflow Y-Pipe (10778) is a good exhaust upgrade and I'm planning to do this ASAP. I'd like some feedback whether I should also go with a Magnaflow CAT? Heard the high flow CAT might trigger a CAT efficiency code?
Does it make sense to go with the high flow CAT as well?
I did install a Magnaflow muffler into the existing pipe. Will plan on welding the Y-Pipe and CAT into the existing pipe as well.
Thoughts?
Stock 2003 Durango 4.7L 4X4
Old 10-03-2012, 04:38 PM
that_guy's Avatar
that_guy
that_guy is offline
Not entirely sure on the 4.7, but I know on the 5.2 and 5.9 the oem cat is high flow.
I have a 3" stainless steel Magnaflow cat-back exhaust with a 3.5" polished tip on my 5.2.
I see you're from Pittsburgh too. Where at?
Old 10-03-2012, 05:41 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
ALL of the stock cats in these trucks are high flow so dont waste your money on that one
Old 10-03-2012, 10:13 PM
Miguelito1961
Thanks...will stick with the Y-Pipe.
that guy...I'm in Murrysville.
Old 10-03-2012, 10:18 PM
that_guy's Avatar
that_guy
that_guy is offline
I know right where that is, I'm from west newton
Old 10-11-2012, 02:59 PM
Miguelito1961
2003 Durango 4.7 4X4
I ordered the Y-Pipe (10778) and it arrived last week. I scheduled an appointment with my exhaust guy to have it installed. Several hours after dropping it off I received a call telling me that the part was not going to work. Apparently the stock pipes from the manifold are more like 2" (maybe slightly bigger) and 2.5" going into the CAT. The 10778 is 2.5 in and 3 out, wrong Y-Pipe.
My guy left the truck on the rack so I could see for myself later that day. The Y-Pipe was definitely too big. Modification and fitment would not have been practical or beneficial. The frame was in the way so very little room to fit this 10778 Y-Pipe.
Was debating to get a different Y-Pipe, but what I noticed after looking at it for myself, was that transition of the pipes from the manifold into the stock Y-Pipe didn't look restrictive at all? The pipes maintained their ~2" diameter into the stock Y-Pipe and then transition into 2.5" out. I've concluded that the exhaust flow is as good as it's going to get without increasing pipe diameter from the manifold back. Leaving it alone for now.
Just thought I would pass this along in case any 4.7 Gen 1 owners are thinking of doing this upgrade. Check the pipes for yourself first to see what you have.
Quick Reply: Magnaflow Y-Pipe / CAT
