3rd Gen Durango 2011+ models
Old 08-06-2015, 07:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Key Fob Battery Replacement
Old 09-28-2012, 09:19 AM
03neonRT's Avatar
03neonRT
03neonRT is offline
Default Key Fob Battery Replacement
Hey all,
The proximity and remote functions of my key fob started to have a terrible range yesterday, and then this morning an error popped up on the center cluster screen saying the battery was low. Is this something I can change myself? Or does the dealer have to do it? I wasn't sure if removing the battery would make it lose its programming or not...this is the only fob I have as well until the second one (new from the dealer) comes in next week. If I can, whats the best way to pry it apart, and what type of battery is used?
Thanks!
Old 09-28-2012, 10:25 AM
undertow999's Avatar
undertow999
undertow999 is offline
Originally Posted by 03neonRT
Hey all,
Thanks!
Check out the owners manual (pg 27) http://www.autodealertools.com/quick...11/Durango.pdf
Basically you remove the emergency key from the fob and use it or a flathead screw driver to pry apart the key fob. Hope this helps.
edit: I think the battery is a DL2032 battery. Not 100% sure but I think that is the correct one.
Old 09-28-2012, 10:35 AM
03neonRT's Avatar
03neonRT
03neonRT is offline
Thanks. I knew it wasn't difficult to change the battery (like other fobs out there)...just wanted to make sure it wouldn't wipe out any programming before I did it since its my only one right now.
Quick Reply: Key Fob Battery Replacement
