Dodge Magnum The Dodge Magnum, the wagon that made wagons cool. The unique look of the Dodge Magnum makes any trim level, from SE to SRT-8, an absolute head turner.
2005 Magnum High Idle on Startup
Old 09-26-2012, 10:54 PM
matt17h20's Avatar
matt17h20
matt17h20 is offline
Default 2005 Magnum High Idle on Startup
Has anyone experienced the same or similiar issue? Upon startup, engine idle spikes to 1200 to 1500 rpm and drops down to approximately 1000 rpms until the engine warms up and then idles regularly around 700 rpms. Did some research and sounds like maybe a idle air control valve or throttle position sensor?
2005 Dodge Magnum 3.5L V6 AWD 90,000 miles
Quick Reply: 2005 Magnum High Idle on Startup
