2000 durango wont start
hi. my 2000 durango with the 5.9 wont start. i bought it like this but i cant figure out why it wont start. i got fuel pressure in the rails and my timing light says i got spark. so i thought it was timing because it has over 200k so i put a timing chain in it and that wasent it. this is the first dodge ive ever owned so i dont know to much about them. its got new coil, pick up coil, cap and rotor by the previous owner. i even checked fireing order on the wires. the plugs are really wet so im gonna clean them off and see what that does also there was a lot of gas in the oil when i bought it i assume from people cranking it so much. if u have any ideas please let me know.
First, the timing in these trucks is set for you by the PCM... there is no need for a timing light... I would look at the crankshaft position sensor as the culprit.
i thought about that, do you know of a way to check if the old is bad before i buy another one?
on
i tookem all out and cleaned them up because they were really wet with gas. but they look to be in good condition nice and flat
