Front Wheel Bearings...2008 Ram
Old 09-22-2012, 12:44 AM
nobby's Avatar
nobby
nobby is offline
Default Front Wheel Bearings...2008 Ram
After some of the research I've done as to the wheel bearing replacement on the front of my truck......I have some comments that say it goes real smooth, pop the axle out yadda, yadda.
Other comments suggest that the control arm gets in the way and it too needs to be moved.
Is the CV joint really that collapsible on these axles?
Anything else I should know?
Of course some of the vids make it look a little TOO easy....it's the video comments I like to read.
And most seem to have a full lift rather that jackstands.
Old 09-22-2012, 09:19 AM
1500hemi4x4's Avatar
1500hemi4x4
1500hemi4x4 is offline
anti seize the hub/spindle once you get the wheel bearing out .and yes on these truck the axle's do seize in the bearing's i have had to heat up and drive the axle out with air hammer.i pop the upper ball joint off the spindle to get at the whell bearing bolts much easy ier
Old 09-22-2012, 06:45 PM
p38251's Avatar
p38251
p38251 is offline
A little dap of lock-tight (blue) on the hub mounting bolts. Had one of mine back out, luck it didn't do any damage.
Old 09-23-2012, 09:56 AM
nobby's Avatar
nobby
nobby is offline
Thanks for the tips.
Anyone else?
Old 10-04-2012, 11:43 PM
nobby's Avatar
nobby
nobby is offline
So much for that little problem.
Dealer replaced the bearing under warranty!
Old 10-05-2012, 09:01 AM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
Nobby,
Glad to hear it was covered under your warranty.
Old 10-05-2012, 10:23 AM
nobby's Avatar
nobby
nobby is offline
Originally Posted by DodgeCares
Nobby,
Thanks. I am quite happy about how things are turning out.
And I am starting to love this truck.
Old 10-05-2012, 01:19 PM
DodgeCares's Avatar
DodgeCares
Nice to hear.
Quick Reply: Front Wheel Bearings...2008 Ram
