Rear Wiper Not Working
Old 09-10-2012, 11:17 AM
SyntheticBlinkerFluid's Avatar
SyntheticBlinkerFluid is offline
Default Rear Wiper Not Working
So one day last fall I turned on the rear wiper, it was working fine. Drove to my destination and shut off all the wipers before I shut the truck off like I normally do, rear wiper goes back to the down position. After I left from my errand, I realized I hadn't turned on the rear wiper, so when I did, it wiped to the point of being vertical and stopped. I shut it of, it did not return to the down position.
So I got home, turn on the switch, it didn't do anything, so I grabbed the wiper and tried to see if I could move it. I could feel it trying to move but it was like it didn't have enough juice to move without my assistance.
I haven't touched it since, but I would now like to replace it before winter comes again. It was kind of annoying not having it all last winter. I tested it again and its going the same thing.
So where should I start looking for issues before I waste a day going to the U-Pull it to get another motor?
Thanks.
Old 09-10-2012, 07:24 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
pull the inside of the door apart and see if you get 12v at the motor when the switch is turned on, if you have 12v there then pull the motor and see if it functions properly out of the liftgate.
If you have power at the motor the issue is either something jamming the motor (removing it should remove the obstruction) or a bad motor.
if it doesnt work anymore out of the door then its the motor. gone bad
Old 09-11-2012, 12:16 AM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Probably corroded from moisture too. If you take it out, do it right and put a new one back in there. Can't be a fortune aftermarket or even dealership.
That's how you keep an old vehicle new. Mine has been replaced a part at a time for a decade.
IndyDurango
Old 09-14-2012, 06:53 PM
coreybv's Avatar
coreybv
coreybv is offline
Mine doesn't work either, and I'll be leaving it that way. It's been awhile since I priced a replacement motor, but I want to say it was in the $300 range. Even if I'm off on that dollar amount, it was definitely high enough to put it in the "I can live without it" category for me.
Tried to find one from a salvage yard, but they won't sell them. Because of rusting issues there's enough of a demand for the rear lift gate as a unit that they won't take the motor out of a non-trashed gate, and when they do get one in with a trashed lift gate, the wiper motor is out the door same day.
Old 09-14-2012, 07:39 PM
Compactc9's Avatar
Compactc9
Compactc9 is offline
I've got a spare 98-00 wiper motor, $70 plus shipping. Came out of the tailgate I bought for my truck, but couldn't use it as the wiring for the 01-03 wiper motors is different.
Quick Reply: Rear Wiper Not Working
