04 intrepid valve body / solenoid pack trouble
Old 09-03-2012, 09:40 AM
montyace's Avatar
montyace
montyace is offline
Default 04 intrepid valve body / solenoid pack trouble
I have a fairly common problem with the trans going into limp mode upon down shift and sometime on up shift. I have changed fluid and filter ATF4, input and output speed sensors, checked and ran new grounds, still nothing. Parts store says P1776 is solenoid valve stuck, dealer trans scan says the valve body is bad. Do I just change valve body or go for solenoid pack as well since it is on top of valve body? Any links to the procedure, hints, tips? Thanks
Old 10-12-2012, 12:06 AM
Benjamins_2002's Avatar
Benjamins_2002
Benjamins_2002 is offline
I was in limp mode, and ended up changing silinoid pack. Since then it's been running great.
Posted from Dodgeforum.com App for Android
Quick Reply: 04 intrepid valve body / solenoid pack trouble
