blower motor resistor
Old 08-17-2012, 11:17 AM
mlwt1163's Avatar
mlwt1163
mlwt1163 is offline
Default blower motor resistor
I'm new to the forum. I've got a 2000 dakota sport, recently acquired. Looking for the location of the blower motor resistor. Have done some reading. It's not under the cowl, etc. as mentioned. It's not to be found on passenger side footwell area, been all around. Am I going to get to take the dash out again? Thanks for any help.
Old 08-17-2012, 12:07 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
It should be up under the cowl you can’t actually see it with your eyes you need a mirror or a scope to see the thing that’s why you need to be Gumby to get to it.
You can only feel it by sticking your arm up under the opening under the cowl
It’s a major pain in the ***
You will have the old style resistor if your system is operated by vacuum how do you tell that if you A/C controller is mounted vertically in the dash it’s a vacuum system if it’s mounted horizontally its an electric servo system with the newer resistor inside the cab
Click on my sig bar below and do some reading
Old 08-17-2012, 12:35 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Under the cowl, near the passenger side wiper arm. There is a cover plate over it you have to remove first.
Old 08-17-2012, 12:50 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Default 00DakDan
00DakDan that’s nice my 98 had no removable plate sure would have been nice I had to be a contortionist to get my pack out then it was fine and that pissed me off.
I guess they added the removable plate after 1998
Old 08-17-2012, 02:19 PM
mlwt1163's Avatar
mlwt1163
mlwt1163 is offline
Thanks, I found it......dash is coming back out.The mounting screws are installed from inside the cab. Only thing Ifeel through the acess hole under the cowl are the resister coils, not screwheads or connector.
Yes, it's the vacuum type....well time for a cold one, then pop the dash.
Old 08-17-2012, 02:23 PM
mlwt1163's Avatar
mlwt1163
mlwt1163 is offline
I'll see if I can post a pic when I get to that point. While I have the dash out, again. Is there anything else that would be worthwhile changing?
Old 08-17-2012, 03:01 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Default Ok if you say so
Ok if you say so have fun!
Old 08-17-2012, 06:02 PM
mlwt1163's Avatar
mlwt1163
mlwt1163 is offline
Dude, I'll not doubt you again.....my bad. Used an inspection mirror and light, took pic, can see the 2 hex screws. There's the bottom end of 2 screws right next to them.
Old 08-17-2012, 06:47 PM
steelshot's Avatar
steelshot
steelshot is offline
just saw your post,i had two resister plates go on me ,im on the third one now.it's a 02 they use two 10 mm screws under dash lined up with radio i think hex head.the last one is real high tech looking and was guaranteed to last i even got blistering fan speeds now.
Old 08-20-2012, 08:08 AM
mlwt1163's Avatar
mlwt1163
mlwt1163 is offline
Well, the resistor is installed, blower still not working.Looking at the list posted on another thread by 98DAKAZ, going to try the relay. The installed relay "clicks" in 3 different control positions. Does this sound right. I don't have the tools to test it.
I really hate fishing trips, and for sure don't need the hosing down I'd get from the dealer....Thanks .
Quick Reply: blower motor resistor
