Truck dies while driving then won't start right away
Old 09-04-2012, 09:45 AM
Depends on what the problem is.
  #32
Old 09-04-2012, 02:26 PM
stef300ex's Avatar
stef300ex
stef300ex is offline
I have 1995 ram 1500 5.2L and I have same problem !!!! the engine stalls any time. I wait a few minutes and I am able to start. I do not know what to do !!
  #33
Old 09-04-2012, 02:38 PM
Figure out what's missing when it won't start.
  #34
Old 09-04-2012, 09:28 PM
peshewa's Avatar
peshewa
peshewa is offline
The crank sensor, the coil & most sensors are packed in hard epoxy resin. When it is all totally cooled off, if it starts right up then poops out after warming up, then consider that anything with a hairline crack where you cant see it may spread open as it expands with heat causing it to run no more, then after it cools off & contracts again, the connections are back to where they need to be to fire off allowing it to start & run. This is really common on GM coil packs - they can bench test fine while cool, but get warm on the engine causing this exact issue. The PCM would be the last thing I would suspect. Crank sensor & ignition coil are my 2 top choices for the real issue.
  #35
Old 09-05-2012, 12:42 PM
Robertm1212's Avatar
Robertm1212
Robertm1212 is offline
I swapped both those out on mine and it still did it. I knew it had to be something with the PCM from the get go bc it wasn't throwing a code and none of my gauges were working until the truck started back up.
  #36
Old 12-28-2012, 11:31 PM
becraftc's Avatar
becraftc
becraftc is offline
Hey Robert, did you ever find the problem? I am having the same problem. I was looking to change the fuel pump/crank/cam sensor but wanted to see what your problem was if it was fixed.
  #37
Old 01-05-2013, 06:58 PM
RedTruckDaddy13's Avatar
RedTruckDaddy13
RedTruckDaddy13 is offline
I had the same problem with my truck. I had to replace the alternator. It runs fine now.
  #38
Old 01-06-2013, 12:01 AM
EthanJohns's Avatar
EthanJohns
EthanJohns is offline
I literally just went through all this funness with my truck. im no tech or anything im just going by what ive done.. check ur battery, check ur alternator. a bad battery and some dumbness were what was wrong with mine.
  #39
Old 01-06-2013, 11:56 AM
becraftc's Avatar
becraftc
becraftc is offline
Sorry, forgot about this thread. It was the TPS sensor. I started wiggling wires under the hood and when I wiggled the wires to the TPS sensor it started to die. Replaced the sensor and fixed the issue. I also posted a vid on YouTube for anyone else that may have difficulty replacing it.
Quick Reply: Truck dies while driving then won't start right away
