03 durango 4.7 engine tick
My 03 Durango which has the 4.7L started ticking around 65k miles, but only in the winter and only for 30 seconds or so...now with 112k miles on it, the noise starts immediately after engine start, is louder, and mostly goes away after a minute or 2. I have read online that this is a common noise but could be several different issues. Can anyone please help? To me it sounds like a few lifters are knocking. Please don't respond to this post if you think its the oil filter...i read that a couple times and that is just ridiculous.
Thanks
Thanks
this is a common thing on the 4.7 because the hydraulic lash adjusters need some time to pump up on a cold start, an oil filter with a bad anti-drainback valve WILL aggravate the problem and make it worse, low oil pressure will make it last longer, low oil will cause it to last longer/indefinitely.
I will inject into this conversation the problem I had with the same noise on 03 Durango. Is common problem. Maybe not your problem but easy to check if you haven't already.
I had a tick that started and would go away when engine got hot, but noise eventually got worse. I thought lifers at first. Problem was broken exhaust maifold studs.Makes very similar noise to stuck lifters. When I fixed studs, noise was and still is gone.
Yep, engine tick is usually either a small exhaust leak, or lifters that are sticky and not pumping back up.
I have solved the sticky lifter tick a few times using a product called Seafoam. Essentially when you are planning your next oil and filter change, buy a can of Seafoam. Read the directions but basically you add it to the engine oil and run and drive the engine so it circulates with the oil.
What it's doing it cleaning the oil system by dissolving the buildup or varnish and sludge that tends to cling to things like the inside of lifters and rocker trunions and such.
Once it's been run through the system according to the directions, drain the oil, maybe flush with a quart of cheap thin oil, and then perform your oil change as usual. New oil, filter...yata yata yata.
Then go for another drive, and report back about the engine tick.
