Leaking Rack and Pinion
Old 07-13-2012, 02:00 PM
rpcollett's Avatar
rpcollett
rpcollett is offline
Default Leaking Rack and Pinion
My rack and Pinion is leaking a little from where the tie rod goes into the rack, does this mean I need a new Rack? I also have a shake on the highway and im thinking this may be why?
Old 07-13-2012, 05:22 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
The leak is not likely to cause any kind of shake. Several things can cause a shake: bad tie-rod ends, bad shocks, etc., etc.
Old 07-14-2012, 11:42 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
New rack? Yes. Only way to fix it. Reasons are many.
Old 07-14-2012, 02:23 PM
rpcollett's Avatar
rpcollett
weedahoe your 2wd right? Ever replaced the rack on urs? Any tips?
Old 07-14-2012, 02:32 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Sorry, never had to replace it. But as for a tip, here are two, download a free copy of the Service Manual from the link in my signature below and make sure you compare yours to the replacement and make sure it is the same length.
Old 07-15-2012, 09:49 AM
Jareski's Avatar
Jareski
Jareski is offline
Leaking pinion seal is a common Ram problem, round these parts anyways. Before I bought mine, I asked if it had been checked. So I crawled under with the dealer and sure enough, slow drip. There is supposed to be seepage, but this was quicker than seepage.
Quick Reply: Leaking Rack and Pinion
