Shakes on highway!!!!
Old 07-09-2012, 10:08 AM
rpcollett's Avatar
rpcollett
rpcollett is offline
Default Shakes on highway!!!!
Okay so please help me out here, I have a 04 Dodge Ram 1500 5.7L 2WD. I have tried many things so far and cant figure out why it shakes at highway speeds (65-above). I have replaced both wheel hubs, and all balljoints and tie rod ends, got an alignment and rotated my tires and it still shakes after all those things. I dont know what else it could be besides maybe balancing tires but it made the same vibration before i rotated so i doubt all four tires are badly out of balance. Any suggestions?
Old 07-09-2012, 10:19 AM
drewactual's Avatar
drewactual
drewactual is offline
steering rack... you should have seen mine, my man.. it was a curious wonder I could direct that trucks path at all..
play develops in the rack and that play is most obvious at highway speeds.. get it fixed.. it isn't something to goof around with..
Old 07-09-2012, 10:33 AM
BCP Service's Avatar
BCP Service
BCP Service is offline
Vibration at accel and decel different?? Driveshaft/U joint !! If same , tires .. period !!
Old 07-09-2012, 11:15 AM
drewactual's Avatar
drewactual
which is what I thought too... until I found out otherwise..
op: does it go bezerk when you brake at highway speeds?
Old 07-09-2012, 12:37 PM
Ellis42's Avatar
Ellis42
Ellis42 is offline
Well depends if it vibrates in front and shakes steering wheel or if the back end shakes, mine along with some others I know had same problem(back end shaking), I changes my brake rotors first just thinking easy fix and nope still shaked so I went ahead and changed U Joints and that took about 85% of the shake out so it's now ok to drive at them speeds and Not be so bad but I believe one of my friends driveshaft was out of balance and that fixed his problem but he also replaced U Joints while driveshaft was off so it could have been either or
Old 07-09-2012, 04:46 PM
rpcollett's Avatar
rpcollett
doesnt go bezerk while braking at highway speeds, and its the same vibration but only once i get to highway speeds. and i can feel it in the steering wheel
rpcollett's Avatar
rpcollett
if it is the rack what goes bad? a seal or what?
Old 07-10-2012, 05:26 PM
p38251's Avatar
p38251
p38251 is offline
Bent rim? When was the last time you re-balanced tires? Tires go out of balance as they wear. less rubber than when there where new. Start with the simple things first. Good luck, let us know what fixes it.
Old 07-11-2012, 02:40 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Make sure all the tires are round with no knots in them or separation also
Old 07-11-2012, 09:26 AM
rpcollett's Avatar
rpcollett
tires are wearing evenly so that looks good, ill try balancing them but i found PS fluid in one of the bellows in my PS rack so.... looks like i need a new rack, im guessing thats where my vibration is coming from but i could be wrong
Quick Reply: Shakes on highway!!!!
