Running lights not working in back
Old 06-30-2012, 11:23 PM
jarebear86's Avatar
jarebear86
jarebear86 is offline
Default Running lights not working in back
Ke the title says my back running lights and dash lights won't work. The cluster word and so do brake lights. I've checked fuses inside the cab and don't see any bad ones. Not totally sure if it could be one under hood. Not real good at electrical to know which one it could even be. Any ideas?
Old 06-30-2012, 11:49 PM
gdstock's Avatar
gdstock
gdstock is offline
Fuse for tail lights. Vehicle wiring is designed so that if tail light fuse blows, the driver can know because dash lights are on the same circuit. Check fuses again. And there are fuses in the PDC under the hood.
Old 07-01-2012, 02:21 AM
jarebear86's Avatar
jarebear86
You wouldn't happen to know which one it is would you? I don't have a diagram telling me
Old 07-01-2012, 09:27 AM
Check Fuse F in the PDC. (under the hood.)
Old 07-01-2012, 01:21 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Why not? https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old 07-01-2012, 06:18 PM
jarebear86's Avatar
jarebear86
There is no "f" fuse. At least mine is not labeled like that. I'm looking at all the fuses and don't see any that are blown. What would it be labeled as?
Old 07-01-2012, 07:17 PM
jarebear86's Avatar
jarebear86
I found it. Parking lamp number one inside cab.
Old 10-08-2013, 06:18 PM
JonAnderson's Avatar
JonAnderson
JonAnderson is offline
Did changing that 15 amp fuse get your back running lights going again?
Quick Reply: Running lights not working in back
