Replacing upper radiator hose question
Old 06-23-2012, 08:58 AM
hoyt66's Avatar
hoyt66
hoyt66 is offline
Default Replacing upper radiator hose question
I am replacing the upper radiator hose on my 2003 Durango (4.7). I bought the replacement hose but....do I need to cut the hose and insert the "t"
connection that has the cap in it? One more question. I have 78000 miles on it. I am flushing and replacing the coolant. Would you replace the t-stat
while I'm at it as a preventive maintenance? Thank you
Old 06-23-2012, 10:40 AM
Old_School's Avatar
Old_School
Old_School is offline
With 78,000 miles i personally would change the t-stat... as for as cutting the hose i cant help ya there as i have a 5.2l and the 4.7 is a gremlin of its own...
Old 06-23-2012, 11:36 AM
hoyt66's Avatar
hoyt66
hoyt66 is offline
Ty Old School. I just picked the D up used and I'm trying to go over some of the maintenance things. Just replaced the plugs this morning. Could you
recommend a good t-stat. I see that the otc ones get some bad press? Thank you
Old 06-23-2012, 11:44 AM
TravisN.'s Avatar
TravisN.
TravisN. is offline
For the upper hose, take the whole assembly of the cap neck, and hoses on both sides off as 1 piece. Trying to get the hoses off the filler neck is nearly impossible for me, so i just replaced that as well (not a hard choice sinse i could see it was leaking slightly from the filler neck). Assemble the hoses outside the vehicle and then install everything as just 1 unit and it will make life much easier. I picked up the replacement filler neck at autozone for about $40, and replaced the cap there too for like $4.
Old 06-23-2012, 12:17 PM
Old_School's Avatar
Old_School
most people (myself included) use the Stant t-stats
Old 06-23-2012, 02:51 PM
hoyt66's Avatar
hoyt66
hoyt66 is offline
Thank you
Old 06-23-2012, 03:49 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
on the 4.7 your best bet for t-stats is the OEM one as it has a weep hole in it which is a necessary feature for that engine, also stick with the factory temperature on the stat (195F)
Old 06-23-2012, 07:05 PM
topdogcustoms's Avatar
topdogcustoms
topdogcustoms is offline
the dealer has the upper hose with new T and new cap for $36 i just bought one autozone was $40 and it didn't come with a cap i also did the t-stat i used a napa it was 8 dollars and i went with a 180 degree its 110 in the summer here and yes i do have a 4.7 it runs cooler and my gas mileage went up so it worked for me
Old 06-23-2012, 08:05 PM
hoyt66's Avatar
hoyt66
hoyt66 is offline
Great feedback. Thank you
Quick Reply: Replacing upper radiator hose question
