6 speed shift points?
Old 06-17-2012, 12:35 AM
kowsoc's Avatar
kowsoc
kowsoc is offline
Default 6 speed shift points?
I have a 2008 Grand Caravan and wondered if there is any way to adjust shift points. Mine are too high under light to moderate throttle....goes to 3000-3500 before shifting. I think it should be more like 2000-2500 for that much load. Older vehicles had the cable that would adjust shifts somewhat but on this van not sure. I think the throttle is drive by wire so how is the trans getting it's info on throttle position? Is there a separate module to control the trans or is it all done with the PCM? Any info would be appreciated.
Old 06-17-2012, 12:57 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Welcome to DF
The PCM/TCM makes all the shift update for the 62TE transmission.
Old 06-17-2012, 07:24 PM
steak59's Avatar
steak59
steak59 is offline
well... there are some software updates to "improve" Shift pattern according to chrysler. And I believe software update on PCM should be covered under 8-80k emmision waranty or Powertrain waranty. check with your dealer on this.
But I highly doubt it will fix your concern.
there is really not much you can do about this other than live with it, or buy another car.
And Unfortuately, I am not aware of any aftermarket Tuners are made for Minivans. Unless Dodge decides to make a SRT Caravan in the future.
Quick Reply: 6 speed shift points?
