drop in oil pressure in a 3.9
Old 06-10-2012, 04:52 PM
dadof4's Avatar
dadof4
dadof4 is offline
Default drop in oil pressure in a 3.9
have a 1999 dodge ram van 1500 with almost 90000 miles after being driven awhile and warmed up when coming to a stop the oil pressure gauge drops to 0 really fast. There is no abnormal engine noise of any kind. Could this be the oil sending unit and if so where is it at?
Old 06-10-2012, 07:14 PM
sparkzz's Avatar
sparkzz
sparkzz is offline
Try changing oil and filter first. You might have a cheap oil filter problem.
Old 06-12-2012, 06:44 PM
DoubleWasp's Avatar
DoubleWasp
DoubleWasp is offline
Change the oil. When I got my van, changing out whatever was in there with a Mopar filter and Mobil Super 5000 oil netted me 30-40 lbs. of oil pressure back.
Old 06-12-2012, 09:55 PM
landyacht318's Avatar
landyacht318
landyacht318 is offline
The reason I installed a mechanical oil pressure gauge is because the dashboard ones are slow and inaccurate at best.
I was gonna buy a real tester but a dashboard gauge was less money. I 'T'd' the line so that my stock gauge still works. The Dash gauge is about 45 seconds behind the mechanical which responds nearly instantly to increasing RPM
When cold, the max PSI is 68 PSI at 800 rpm, or at 4000rpm. 68psi is the oil pump relief pressure.
When hot this drops to ~63 psi
But at 550 rpm hot as it gets idle, I get 18 PSI with M1 TDT 5w-40 in the sump.
63 PSI is reached, when hot, at 1900 to 2100 rpm.
My factory service manual says 8 to 40 psi at idle is acceptable.
Some oils shear out of grade with age and abuse.
Sometimes fuel dilution in the oil will thin the oil and reduce it's viscosity so less psi makes it to the sender.
Old 06-12-2012, 11:55 PM
blackvan's Avatar
blackvan
blackvan is offline
I would say it's either low on oil or there may be a problem with the oil pickup. When mine got a little over a quart low last year my oil pressure gauge would drop to 0 on hard stops and the check engine light would flash on for a second. After a second the oil level would recover and the pressure returned. Safe to say I keep a closer eye on the oil level now
Old 06-14-2012, 11:20 AM
funair02's Avatar
funair02
funair02 is offline
are you sure you aren't dumping coolant from the intake or head gasket into the pan? That would cause your problem. Just a thought..BTW coolant settles below oil...
Old 06-14-2012, 12:32 PM
iodj44's Avatar
iodj44
iodj44 is offline
A mechanical gauge will help you figure the problem, at
the moment the true oil pressure is unknown.
The factory gauge is just not trust worthy.
Quick Reply: drop in oil pressure in a 3.9
