Cracked exhaust manifold
Old 06-04-2012, 12:36 AM
TGoodwin's Avatar
TGoodwin
TGoodwin is offline
Default Cracked exhaust manifold
Hello,
I recently started getting an intermittant check engine light. The code came back as a #8 cylinder misfire. Looking over the engine I ran across this.
This is a 98 Dodge Ram 1500 5.9l Magnum. Is this a common problem on this model?
Old 06-04-2012, 12:42 AM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
That's a great excuse to get some good shorty headers and a new, better flowing y-pipe.
You can thank me later
Old 06-04-2012, 01:39 AM
SilverSS's Avatar
SilverSS
SilverSS is offline
Lol yep good excuse for headers! Not a common problem as far as I know. Mine are fine. If you don't want to get headers an exhaust shop should be able to weld it cheap.
Old 06-04-2012, 02:33 AM
TGoodwin's Avatar
TGoodwin
TGoodwin is offline
Default Headers
LOL
Yeah I already changed the stock manifolds out for some headers.
http://i1068.photobucket.com/albums/...0606200110.jpg
Old 06-04-2012, 09:38 AM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
You need to adress the y-pipe if you want to see any serious performance gains. It's rather restrictive
Old 06-08-2012, 08:17 PM
TGoodwin's Avatar
TGoodwin
TGoodwin is offline
Well I went ahead and bought a Flowmaster cat-back, plenum repair kit, new NGK O2 sensor, MSD 8.5 plug wires, NGK iridium plugs, Harland Sharp 1.7 rockers and Superchips programer to go with the new Gibson headers. So I guess I will keep the truck for a while. :-)
http://i1068.photobucket.com/albums/...0606200158.jpg
Old 06-08-2012, 08:23 PM
TGoodwin's Avatar
TGoodwin
TGoodwin is offline
Default Y pipe
So I see a bunch of Y-pipes. How do I figure out which one is better flowing?
Thanks
Ted
Old 06-08-2012, 08:51 PM
The off-road y-pipe (no cat) flows best. If you can get away with that where you are, go for that one.
Otherwise, post links to the candidates.
Old 06-09-2012, 04:44 AM
ReadRam's Avatar
ReadRam
ReadRam is offline
OP were there any other symptoms from the cracked exhaust manifold as i get intermittent cel #8 misfire?
Old 06-09-2012, 10:27 AM
TGoodwin's Avatar
TGoodwin
TGoodwin is offline
Heavy pinging under load. Slugish performance. Rattle sound coming from the cat sometimes during idle. Oil usage with no external leaks to account for it. The #8 plug was not excessively fouled compared to the other cylinders but the plugs were worn and due for replacement.
The truck is in very good condition with 108k miles on it.
I do not drive the truck daily to work and am doing a little bit at a time. I now have the plugs, wires, headers, and rockers installed. I hope to get time to do the intake kit install today.
Quick Reply: Cracked exhaust manifold
