Low Tire Light 08 RAM 1500
Old 05-27-2012, 07:18 PM
chadw90's Avatar
chadw90
chadw90 is offline
Default Low Tire Light 08 RAM 1500
Is there any way to disable the tire pressure monitoring on these trucks?
I want to put a set of different rims on my truck, the rims already have tires mounted on them and I dont want to dis mount them, put sensors in and re mount. Is there any way to fool that module? I have a DS Predator tuner, but no option in there like there is to turn off MDS.
Old 05-27-2012, 07:31 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
I suspect not, since it's a safety thing. It's probably tied in with the ABS, so pulling the fuse may not help. Since there is so much computer control, the thing may not be fused in the traditional sense.
Old 05-27-2012, 07:52 PM
chadw90's Avatar
chadw90
chadw90 is offline
my truck is an sxt, and does not have abs, my 07 did not have this tpm, and here in Saskatchewan where it gets to -35 degrees Celsius in the winter, my low tire light comes on all the time, quite annoying
Old 05-28-2012, 11:26 AM
1 bad bolt's Avatar
1 bad bolt
1 bad bolt is offline
i just went from 20'' wheels to 17'' , had to pull the sensors from the 20's and put them in the 17's everyone including the dealer said it cant be shut off
Old 05-28-2012, 11:34 AM
MikeHTally's Avatar
MikeHTally
They all have ABS. Yep, those temperature swings will set it off. My Mazda even complains when there is too much pressure.
Old 05-28-2012, 12:56 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Yes, REAR ABS to be exact. Front ABS was an option.
I'd have to look at a wiring diagram to see if you can do something about those sensors. I would think that the cluster is involved and if so, there's prob no easy way or anyway at all around not having them.
I'll take a look tomorrow on my day off.
Old 05-29-2012, 12:43 AM
dakotatrevor's Avatar
dakotatrevor
dakotatrevor is offline
Pull the bulb from the cluster, that's about all you can do. I don't think they are a 'safety thing', or tied into abs at all, just a sensor in the valve stem.
Quick Reply: Low Tire Light 08 RAM 1500
