Old 08-06-2015, 07:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical System
Print Wikipost
DIY - replace Crankshaft Position Sensor on 2001 Ram 1500
Old 05-02-2012, 10:13 PM
jeff351's Avatar
jeff351
jeff351 is offline
Default DIY - replace Crankshaft Position Sensor on 2001 Ram 1500
My truck has the 5.2L, so the CPS is on the passengers-side, rear of the block. (pix were taken by jamming my camera between the firewall and valve cover)
The only tricky part of this task was 1) actually finding the CPS, 2) figuring out what size bolts hold it down, and 3) how to reach it.
Once you actually do find it, the next thing is how the hell...I found it easier to get to while I had the plug wires off the truck. For reference the transmission dipstick tube passes right over it.
With the CPS removed, you can see how it works. The flywheel is visible through the hole the CPS drops into.
The two bolts holding it in are tricky to locate. A couple of drop lights and a mirror come in handy. They can be removed either with a 1/4" allen wrench of 1/2" socket. I found it much easier to fool with by using a couple of extensions, and a cordless drill with a 1/4 hex head socket. The tape holds the stuff together so it doesnt fall apart as you wiggle it into position.
When you reinstall the new CPS, it drops right in, but expect to crawl under the truck a few times to retrieve the bolts while trying to get them started. The shop manual says torque the bolts to 70 in.lbs; not having room for a torque wrench in there, I cranked mine down on max setting with my drill, called it good enough.
Old 05-03-2012, 06:55 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Nice write up. You did install the rubber grommet too right?
Old 05-03-2012, 09:24 AM
Wombat Ranger's Avatar
Wombat Ranger
Wombat Ranger is offline
I never saw a rubber grommet in mine, or with my new part. Hopefully it doesn't cause issues... Photo of said grommet?
Old 05-03-2012, 09:44 AM
zman17's Avatar
zman17
zman17 is offline
A new sensor does not come with one. It's an OEM part. Keeps out dirt/debris/water.
Old 05-03-2012, 09:58 AM
Wombat Ranger
Old 05-03-2012, 10:09 AM
zman17's Avatar
zman17
zman17 is offline
No..... Well it's the part, but not the right application by the looks of it.
Old 05-03-2012, 10:20 AM
A_POLVADO's Avatar
A_POLVADO
A_POLVADO is offline
Leave it to Zman to actually have one he could take a picture of.
Old 05-03-2012, 10:29 AM
zman17's Avatar
zman17
zman17 is offline
.... Anyway, it's from a 98 w/auto trans. I don't know what truck 2x1972 is referring to . LOL
Maybe the one he posted is right. This is from the 95 part manual( available in the FAQ/DIY section). LOL
never mind, I think that is just a timing probe plug.
Old 05-03-2012, 11:40 AM
Pronk's Avatar
Pronk
Pronk is offline
Is the CPS located in a different spot for the 5.9?
Old 05-03-2012, 11:52 AM
zman17's Avatar
zman17
zman17 is offline
No......
Quick Reply: DIY - replace Crankshaft Position Sensor on 2001 Ram 1500
