Valve Springs
Old 05-01-2012, 03:20 PM
Willy McNasty's Avatar
Willy McNasty
Willy McNasty is offline
Default Valve Springs
Does anyone know if this is a fairly simple DIY mod?
What is the best brand of Valve springs to replace my stock ones with?
Thanks
Old 05-01-2012, 08:32 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Fairly simple swap.
Manley Springs are probably the best - BUT EXPENSIVE. Mopar 6.1 Hemi springs are probably just as good, much stronger than the 5.7 springs and about a third the price of the Manleys even from a dealership.
Beware Comp springs, lots have guys have "upgraded" to them only to see one or more break...
Old 05-07-2012, 09:58 PM
jj141979's Avatar
jj141979
jj141979 is offline
im assuming your talking about the 06' Ram Hemi in you sig. unless you are changing the cam, i wouldnt worry about swapping out the springs. the 06's didnt have the issues with the springs like the 03's did. i have an 03' and for me it was a Pain In The A**. those little keepers suck!!!!!! i wouldnt at all worry about swapping those springs unless i were changing the cam!
Old 05-08-2012, 08:11 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Agreed but in case you or anyone else did want to do them, you could follow my How To Change a Cam in our FAQ section and follow the steps pertaining to pulling the springs. Pulling the heads means new head gaskets and bolts ($100) and you need a special tool to pull and replace the springs.
Quick Reply: Valve Springs
