newbie questions
Old 05-01-2012, 02:55 PM
99-neon's Avatar
99-neon
99-neon is offline
Default newbie questions
Hello everyone. I have been doing some reading here and now I have some questions. I just picked up my first Neon.....
'99 SOHC, 2 door, 5 speed, 125,000 miles. The PO did head gasket at about 70,000 but it needs some attention. I just ordered some parts...
motor mounts (both), plugs, wires, shift cable bushing kit, oil pan gsk, radiator, radiator hoses, CPS.
It is pulling a code of P1294 (idle) it wont idle below 1100rpm so I am thinking the IAC valve needs replaced????? Did anyone have any luck with just removing, cleaning it and re-installing their's. They are a little expensive but if it needs it then I will order one. Any other info for a new owner? Problem area's? I read about the CPS harness wires and will take a close look at that when I put the new CPS on.
Thanks for the help. Great forum. Jason
Old 05-01-2012, 08:59 PM
das2123's Avatar
das2123
das2123 is offline
I would pull the throttle body and give it a good cleaning. You can clean up the iac at the same time. I have done it and made a nice difference. Try to find out if the water pump, idler pulley and timing belt were changed along with the hg. If not, you will want to get that done.
Quick Reply: newbie questions
