How to replace heater/ac control knob
Old 04-17-2012, 04:43 PM
georgi's Avatar
georgi
georgi is offline
Default How to replace heater/ac control ****
Could you tell me please how to replace heater/ac fan control **** on Dodge Caravan 2001.
Someone install it backwards (turned on 180 degrees). Can I just pull it out or I need to remove the whole dashboard?
I found out that **** can be taken off in one position only - turn it to the left to the end (counterclockwise).
I removed two of them but the wrong one wasn't.
Any ideas?
Old 04-18-2012, 12:10 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
I believe the ***** come with the control head. To replace the control head the center bezel needs to be removed.
Old 04-21-2012, 04:20 PM
trophyslayer's Avatar
trophyslayer
trophyslayer is offline
I had a button that did that on my 06
I had to replace the unit with one I found on ebay for 35$
it was plug and play
as long as you get the unit from similar year van, not older, and can see a pic of it to make sure it looks like yours
Old 04-23-2012, 11:13 AM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
The one that is f'd up also pulls off, it was probably broken and someone glued it on. A little black and white paint and problem solved.
Quick Reply: How to replace heater/ac control knob
