Adjust transmission cable
Old 04-13-2012, 10:30 PM
thelaminator's Avatar
thelaminator
thelaminator is offline
Default Adjust transmission cable
98 dodge 1500, I was told to take the tv cable clip off and while the gas pedal is to the floor, lock the clip in place. The transmission shifts real smooth but it seems like I'm going threw more gas. Is this possible? And how should I adjust?
Old 04-13-2012, 10:48 PM
gdstock's Avatar
gdstock
gdstock is offline
Whoever told you to adjust this with gas pedal to floor has lost their mind. If tranny is shifting well, TV cable is not the issue. I would not mess with it.
Did gas mileage suddenly drop from what it was?
Have you downloaded the service manual from the FAQ/DIY section?
Old 04-13-2012, 11:08 PM
jswain's Avatar
jswain
jswain is offline
With throttle blades closed, the cable clip should be aligned with the stud on the throttle body with no slack in the cable. Is my understanding anyway. I've set mine at this position, and adjusted the cable for slightly firmer shifts. I do notice a slight (1 MPG) decrease with the firmer shifts. Google "bionic dodge, TV cable adjustment". Has a pretty good article with pics. Or reference svc manual as said earlier for factory adjustment.
Old 04-14-2012, 07:14 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Quick Reply: Adjust transmission cable
