Old 08-05-2015, 12:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
DIY - Transfer Case Saver install (NP231, NP241, NP243)
Old 04-11-2012, 11:35 PM
Wombat Ranger's Avatar
Wombat Ranger
Wombat Ranger is offline
Default DIY - Transfer Case Saver install (NP231, NP241, NP243)
I've never attempted a DIY writeup before. This is a fairly common topic with these trucks, so I figured it's worth a shot. I couldn't find another one on this forum, so here it is. This writeup covers the installation on my 1995 Ram 2500 with an NP241 DLD 23 spline input.
NOTE: This kit may not be compatible with some/all NP241 HD Transfer cases. In the words of Zman17:
Originally Posted by zman17
The tailshaft housing does not come off by simply removing the 4 bolts on a 241HD, something has to be removed from the inside of the TC to take it off. I called Dan at Quad 4x4 at the time I was trying to install mine to confirm. He also said he needed to change the description of what TC's it fit's. This is the reason I sold my TC saver. Besides, I think the shaft is bigger anyway.
Thanks Zman for a good deal on the part!
Transfer Case Saver Installation
1) Put your truck in neutral, set the parking brake, and chock the wheels.
2) Remove your rear driveshaft. On mine this is accomplished by unscrewing the 4 bolts that hold the u-joint straps in place, then sliding the driveshaft forward and free of the pinion yoke, followed by pulling it backwards and out of the T-case tailhousing. Starting in 2000 the 1500's stopped using U-bolt straps, switching to a 4 bolt flange design. My truck is not this way. If yours is, DON'T PANIC!!! Dial 911. Then remove your 4 bolts and follow the rest of my instructions. HD's did not switch to this design in 2000. A negligable amount of ATF will come out of the transfer case. On my 2500, the size used for the bolts was 5/16".
3) Unbolt the 4 bolts that fasten the tailhousing to the rear bearing retainer. Mine were 1/2" heads.
To get the tailhousing loose you may have to use some force, since it should have had a silicone sealant used on it. I just pulled down on it with my arms, but a smack with a deadblow would do just fine as well.
This is why my truck needed the Tcase saver in the first place. as you can see, the snap ring popped out of its groove, leaving the mainshaft loose to move around at will, eventually causing destruction of expensive internal parts.
This is how the factory snap ring is supposed to function. Many people have had them break, and mine just wouldn't hold it's shape.
4) If your snap ring was still in it's correct place, use a pair of snap ring pliers to remove it (or needlenose pliers like me )
5) This is a picture of the Transfer Case Saver installed. It simply has 2 allen head screws holding it together. The ring itself has a lip that sits in the snap ring groove, providing better security to the placement of the mainshaft. My kit came with red Locktite to put on the threads, to keep them from backing out.
6) Clean up your mating surfaces in preparation to re-install the tailhousing.
7) Put a nice thin bead of RTV silicone (I used the Ultra Black flavor) on the tailhousing. If your bead doesn't look as gangster as mine, that's okay, cuz mine is pretty thug.
8) Re-install the tailhousing and driveshaft, wait an hour for the silicone to cure, and enjoy a trouble free transfer case!
Old 11-24-2012, 08:42 AM
Halojm's Avatar
Halojm
Halojm is offline
Where can I purchase one of these? I have some play in the drive line that seems to be in that area, plus the clunk sound when I put it in reverse only. I'm a little suspicious.
Old 11-24-2012, 11:38 AM
Wombat Ranger
Google it. I think its www.drivetrain.com, but I can't exactly remember...
Check your U-joints too.
Old 11-24-2012, 12:02 PM
gertie240's Avatar
gertie240
gertie240 is offline
really nice write up and camera work.
Old 11-24-2012, 12:25 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Nice DIY. However, beware that the saver does NOT fit some 241's even though they are 4 bolt. The tailshaft does not come off some of them without opening up the TC. Which is why I sold mine to wombat.
Old 11-24-2012, 05:46 PM
Wombat Ranger
When I did this write up last spring you said the same thing Zman, and it's noted at the top of my post. Getting forgetful in your old age Z?
Thanks Dood.
Old 02-05-2013, 06:37 PM
My360's Avatar
My360
My360 is offline
Nice write up, I'm definitely going to have to look into getting me one of those.
If your getting a clunk when putting it into reverse only, try checking the rear universal first. That's usually the cause of that clunking noise.
Old 02-06-2013, 06:32 PM
oxymoron29's Avatar
oxymoron29
oxymoron29 is offline
Correct me if I'm wrong, but isn't this "kit" simply a regular plain old shaft collar?
These things are common as dirt; simply need to know the shaft diameter and that's a $5 at most fix from a local industry supply versus a $60+shipping eye gouging.
Old 02-06-2013, 09:43 PM
Spillage's Avatar
Spillage
Spillage is offline
Not quite... they have a flange that goes into the snap-ring groove.
Old 04-16-2013, 11:25 PM
spun360's Avatar
spun360
spun360 is offline
let me ask a dumb question. is it unusual for a ram 1500 to have a np231?
my truck is a 96. now that i have a new and improved 325 horse power plant, i feel the need to look over things and beef them up. will this pipe bushing fit my truck?
Quick Reply: DIY - Transfer Case Saver install (NP231, NP241, NP243)
