06 Ram 1500 - 545RFE Trans. fluid capacity
Old 04-06-2012, 12:23 PM
cdn-pk's Avatar
cdn-pk
cdn-pk is offline
Question 06 Ram 1500 - 545RFE Trans. fluid capacity
First i have to say, i love the site, been coming here for repair info and aftermarket part info for years (probably 2003ish). Had a 95 ram and recently upgraded..... which now leads me to the need for my first post.........
Just did the fluids on a new to me:
2006 dodge ram 1500 SLT Quad Cab 4x4 with the 545RFE transmission and the tow package.
I changed out the transmission filters and drained the fluid (no i didn't flush). But here is the problem, i spilled at least a litre ... at least a litre probably more. so i know for sure i pulled out 8 liters. So i put back in 8 litres.
but,
When cold the fluid is close the the Top lower hole, After i wipe the dip stick and put back in (all the way) and pull it out it's hard to get a good reading, my gut tells my i should add more. So i took her for a 130km trip the fluid was warm (not hot) and then the fluid would read above the second hole.
Previously the fluid was in between the upper two holes when hot, now i can't seem to get it hot enough and it is not showing between the upper two holes.
How can i determine if i have enough fluid in. Or how could i heat up the tranny with out abusing it.
Other information:
1) vehicle always checked level, running and i go through all the gears stopping from 2-5 seconds, leaving it in Neutral to check fluid level.
2) for those that can't remember 1 Litre is approximately 1 US Quart (1 US Quart = 0.946 L)
3) the Haynes manual says 6.0 quarts, which is BS because i pulled out more. and i have read capacities here from 6L to 16.5L. So i think i need a little direction.
4) Transmission does not display any problems that i could relate to low fluid, i goes great in all gears, shifts seem as good as they were.
Thanks
Old 04-06-2012, 03:35 PM
Dudemanbrother's Avatar
Dudemanbrother
Dudemanbrother is offline
The total capacity is 17 qts. You have to get it to operating temp to check it accurately. So however long it takes driving around to get your temp gauge to its usual spot, then find a level spot, run through the gears, back to neutral and check. If its past the two hot holes, then you need to pull some fluid out until its between the two hot holes.
Old 04-06-2012, 04:11 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
When I did the drop 'n' drain and change both filters on mine, it took seven quarts to bring the mark to full-hot.
Old 04-06-2012, 05:27 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Get tranny up to operating temperature. This means when you pull the dipstick the fluid should be hotter to touch than you can handle, or atleast hotter than comfort.
Put the truck on level ground and get it in nuetral and put the e-brake on. With the truck Running, Check your fluid. It should be at the top hole. A little bit higher wont hurt, but you want it at the top hash/hole mark. Not too high or the fluid could froth and actually do more harm than good.
Old 04-06-2012, 09:40 PM
cdn-pk's Avatar
cdn-pk
cdn-pk is offline
Thanks guys, guess i'll take a load of lumber to the cottage and stop periodically and check it until it heats up enough. I was hoping to get her topped up before hauling but, looks like it'll be the fastest way to warm up the fluid.
Happy Easter everyone
Update:
well i drove out to the cottage (approx. 135km) with about 1000lbs in the back, heated up the tranny a bit more but still not enough. it was cold out so i guess the transmission cooler was doing it's job. i'll have to try a bunch of city driving, or perhaps a short trip hauling 1/2 or 1 yard crushed rock.
Old 07-15-2012, 02:03 PM
dbier63's Avatar
dbier63
dbier63 is offline
Thank you sir this is finally the info I've been searching for.
Quick Reply: 06 Ram 1500 - 545RFE Trans. fluid capacity
