Power Steering Leaking with PIX!!!
Old 03-28-2012, 06:36 PM
Donmega884's Avatar
Donmega884
Donmega884 is offline
Default Power Steering Leaking with PIX!!!
I have a leak, and I have found where it is coming from. What do I need to remove/replace to fix this leak?? This is the only area it is coming from, and it drips like a leaky faucet.
Attached Thumbnails Power Steering Leaking with PIX!!!-dodge-ram-2.jpg   Power Steering Leaking with PIX!!!-dodge-ram-ps1.jpg
Old 03-28-2012, 06:48 PM
Matt Nickerson's Avatar
Matt Nickerson
Matt Nickerson is offline
That would be your pitman shaft seals going bad. You can just replace those seals. Or throw down 3-400 bones ($) for a new box.
It's an easy fix, disconnect everything from the gear box (PS lines, pitman arm, steering shaft) and remove the bolts from the frame. Pull the shaft out and empty the fluid from the gearbox, replace the seals (and the bearing if you want) put everything back together...and refill the reservoir and gearbox with PS fluid. Bleed the system, I think thats about it.
Here's a DIY: http://www.pavementsucks.com/tech-article-34.html
I;d also recommend downloading the Factory Service Manual from the FAQ's sub-forum, the procedure is in there along with all the adjustments and the torque specs you might need for the gearbox.
Old 03-28-2012, 07:00 PM
silverram2000's Avatar
silverram2000
silverram2000 is offline
i have the same leak, but i have to turn the 36's. the seals are like 20-30 bucks.
Old 03-28-2012, 08:19 PM
Donmega884's Avatar
Donmega884
So I'm going to need this?
http://www.autozone.com/autozone/par..._151370_12408_
Should I replace the pitman arm itself too?
Old 03-28-2012, 08:27 PM
Matt Nickerson
Yup, that's it. The 4 small "circles" are the seals, snap ring, and washer. The bigger one is the seal for the top of the side cover housing (the cover with the four bolts that attaches to the other end of the pitman shaft). If you're near a dodge parts dealer (Autozone/Napa might have it too) pick up the needle bearing(s) for the shaft as well. Don't forget to get power steering fluid too.
Have someone turn the wheel as you look at the pitman arm. If there's a delay (a little might be okay) in the movement of the pitman arm when the steering wheel is turned, replace it.
Old 03-29-2012, 12:17 AM
johnnyjaws98's Avatar
johnnyjaws98
johnnyjaws98 is offline
just get a new steering box from auto zone 156.00 dollars + 80.00 core charge 1yr warrenty
Old 03-29-2012, 12:27 AM
gdstock's Avatar
gdstock
gdstock is offline
That's the seals. If there is a little play in the gearbox, it can be corrected. See sevice manual for details. Get a good puller for pittman arm. They can be a PITA to get off. Good time to check tie rod ends for play as well.
Old 03-29-2012, 04:33 PM
kadetklapp's Avatar
kadetklapp
kadetklapp is offline
Wonder if this is where mine is leaking. I've had a "mystery" PSF leak pop up.
Old 03-29-2012, 09:04 PM
95BIGRED's Avatar
95BIGRED
95BIGRED is offline
i just did mine 2 days ago for 220 with lifetime warranty. took less than two hours. to avoid the core charge pull yours out and take it to em before you buy a new one. lol verify they have one first. i replaced the hose's while i was in there too.
Old 03-30-2012, 06:45 PM
KG120's Avatar
KG120
KG120 is offline
I'm having the same problem...I don't see the service manual you're talking about..How do I find that?
Quick Reply: Power Steering Leaking with PIX!!!
