Check engine soon light 1997 Grand Caravan
Old 03-20-2012, 10:01 PM
Joshua Frey's Avatar
Joshua Frey
Joshua Frey is offline
Default Check engine soon light 1997 Grand Caravan
I did the On Off On Off On thing to get it to spout the problem codes, and wrote down the number of times it flashed, but am having trouble finding out what those codes are. Everything I've found says that it will give me a reading where my mileage is, but it doesn't.
The numbers are 1 2 4 3 6 6 7 2 6 6 5 5. I know that the 1 2 is the start and the 5 5 is the end, but I have no idea what the middle ones are. Can anyone tell me what they are and/or where I can find out? I would be most appreciative!
Old 03-21-2012, 02:02 AM
Cougar41's Avatar
Cougar41
Cougar41 is offline
12 - Battery disconnected in last 50 key cycles
43 - Ignition coil primary circuits
66 - No CCD messages from TCM or BCM
72 - Catalyst efficiency below spec
66 - "
55 - End of codes
Head to an AutoZone where they will connect a scanner and read your codes for free. 4 digit scanner codes are going to give you more specific information then the 2 digit key dance codes. For example, code 43 can be broken down to 10 scanner codes.
As I recall the code readout on the odometer started in late model 3rd gen vans 99-2000. 4th generation vans for sure 2001 and up.
Old 03-21-2012, 01:53 PM
Joshua Frey
Ok, thanks for the information. I'll head to Auto Zone tomorrow when the snow melts.
Quick Reply: Check engine soon light 1997 Grand Caravan
