3rd Gen Durango 2011+ models
Stereo wire color codes?
Old 03-19-2012, 11:31 AM
cjlucas78's Avatar
cjlucas78
cjlucas78 is offline
Default Stereo wire color codes?
I am going to be switching my factory speakers to focals front/back with a Sundown Audio Amp. I will also be adding 2 Solobaric 12L7s behind the 3rd row seat. I will be keeping the factory radio (for the stealth factor when theives look in). I would like to know what the color code is on the wires on the back of the radio so I can tap into the factory wiring.
Thank you, I will get build pictures soon.
Old 03-19-2012, 12:46 PM
baum's Avatar
baum
baum is offline
Search the forum (radio, amp, subs...) i have posted them before.
Old 03-20-2012, 09:20 AM
cjlucas78's Avatar
cjlucas78
I searched with no luck, that is why I posted. I even searched your posts and could not find where you posted the list of stereo wire codes for the 2011-2012 Durango.
Old 03-20-2012, 09:57 AM
dpayerle's Avatar
dpayerle
dpayerle is offline
Here's a link to the color codes on a grand Cherokee forum.
http://www.jeepgarage.org/showthread.php?p=414994
Dan
Old 03-20-2012, 01:19 PM
baum's Avatar
baum
baum is offline
If you have the 9 speaker system i would recommend taking the signal after the factory amp. If you go before the factory amp there isnt enough signal.
Be sure you know what you are testing when installing there is another member on here that taped into the wrong wire and fried out the win module while installing an amp.
Old 03-21-2012, 09:50 AM
cjlucas78's Avatar
cjlucas78
I do not have the Alpine system with sub and amplifier, I only have 6 speakers. I did not want to pay for the nice radio knowing I would be changing it out.
Quick Reply: Stereo wire color codes?
