Dodge Intrepid Noise
Old 03-12-2012, 09:20 AM
apappal's Avatar
apappal
apappal is offline
Default Dodge Intrepid Noise
Ok guys, you usually come up with some suggestions for me so here it goes, I have an 01 Intrepid, when I hit about 20mph, I get a sound that is like what you hear when you are driving on rumble strips. It increase with speed. Any thoughts??
Old 03-23-2012, 12:53 PM
deancf's Avatar
deancf
deancf is offline
is it coming from up front, rear more info, is it a tick, or a knocking noise.
Old 04-09-2012, 01:56 PM
apappal's Avatar
apappal
apappal is offline
Ok, the sound is more like a rumble or growel then a tick, low frequency. Also, it is coming from the front, I'm leaning towards rotor, will know more tonight when I pop a wheel off as it has gotten louder since it started and is annoying as heck.
Old 04-24-2012, 09:38 AM
apappal's Avatar
apappal
apappal is offline
Unhappy
Well, I figured it out, the bearing on the output shaft on the drivers side went and took a chunk out of the housing. Car is officially DOA
Old 04-30-2012, 09:23 PM
MagicMan407's Avatar
MagicMan407
MagicMan407 is offline
Apappal what exactly is the bearing on the output shaft? I think I have the same problem. it isn't a knock or tick more like a slow rumble.
It starts when I reach around 20-35 mph and take my foot off the gas. I cant hear it when I'm accelerating or going over 40 mph. Only when I'm not touching any of the pedals I hear this. I'm worried it could develop into something bad if I dont find out what it is.
Old 05-23-2012, 08:33 PM
deezozdodge's Avatar
deezozdodge
deezozdodge is offline
Check bushings. Raise the vehicle and check for free-play by holding the wheel and tire and moving it side-to-side and up-and-down. There should be no free-play. If there is free-play, have someone check the bushings as you move the tire.
Quick Reply: Dodge Intrepid Noise
