Brakes Pulsing - changed all rotors/pads - now slightly worse....
Old 03-12-2012, 09:04 AM
Bob Cosby's Avatar
Bob Cosby
Bob Cosby is offline
Default Brakes Pulsing - changed all rotors/pads - now slightly worse....
I have a 2008 2WD Hemi with just over 80k miles. At about 60k, my brakes started pulsing, so a few thousand miles later, I changed the front rotors/pads. Nothing changed. Yesterday, I got around to doing the rear. Same thing - new rotors/pads. This actually made it slightly WORSE.
The caliper plungers all *seemed* to compress back into the calipers with about the right amount of force. I have plenty of brake fluid.
Ideas? Very annoying!
Thanks!
Old 03-12-2012, 11:50 AM
MoparMan1991's Avatar
MoparMan1991
MoparMan1991 is offline
Maybe your brake lines are starting to collapse? Maybe replace them with the high quality steel braided lines.
Old 03-12-2012, 12:48 PM
scwpd's Avatar
scwpd
scwpd is offline
Even tho the calipers felt fine you could still have one sticking
Old 03-12-2012, 12:59 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Also, don't just assume those rotors were not warped a little out of the box. I just did the rears on my Grand Cherokee after I had a caliper decide to lock up - taking out the pad and rotor. Brand spanking new Autozone rotors were slightly warped out of the box and I had to turn a hair off of them to get them right...
Old 03-12-2012, 07:25 PM
jrsick's Avatar
jrsick
jrsick is offline
bad tie rods can give the same feel. If the truck gets bouncy when you're coming to a stop then it could be the tie rods.
Old 03-12-2012, 09:36 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
I agree with worn tierods. If there's any slop in the joints they will shimmy back-forth when the brakes are applied. Most of the time, they will shimmy and gradually go away or get worse until you slow right down. They generally wobble at higher speeds which makes you think they are rotors.
I'd grab ahole and vigoruosly shake. If nothing, then use a pry bar to see if there's slop. They should barely move with a bar and not at all by hand.
Old 03-13-2012, 08:07 PM
Bob Cosby's Avatar
Bob Cosby
Thanks for the input. Will take a look at all!
Old 03-13-2012, 08:49 PM
boosted-fc3s's Avatar
boosted-fc3s
boosted-fc3s is offline
Dont forgot about the lug nuts. Did you use a torque wrench to tighten the lugs evenly to the same spec?
Old 03-13-2012, 09:41 PM
Magnum4406's Avatar
Magnum4406
Magnum4406 is offline
I have had warped rotors right out of the box before. I put pads and rotors on my Durango and the new ones were worse than the ones I took off. I had to resurface them and them it was smooth.
Old 03-14-2012, 07:19 AM
Bob Cosby's Avatar
Bob Cosby
Hmmm....what about the shoes for the parking/emergency brake on the rear?
Quick Reply: Brakes Pulsing - changed all rotors/pads - now slightly worse....
