Rattling Front End Solved
Old 03-10-2012, 09:04 PM
boosted-fc3s's Avatar
boosted-fc3s
boosted-fc3s is offline
Default Rattling Front End Solved
Finally got around to taking apart my front end. My front end has been rattling like crazy even at low speeds over the smallest of bumps.
Since I was taking apart the sway links anyways, I went ahead and swapped out the bushings with energy suspension polyurethanes for the end links and 36mm bushings for the bar itself. Took about 3.5-4 hrs to get everything done, some rust issues, and a sheared off upper link (see pics). Happy to say the front end is quiet as can be now. Handles btter now too that my sway bar is no longer essentially disconnected. Apart from the really bad one in the pic, the passenger side had over 3/8" of play in it.
Apparently this is the result of what I'm assuming is OEM sway links with 170k on them:
Old 03-10-2012, 09:59 PM
NV290's Avatar
NV290
NV290 is offline
I had a knock in my front end too for about a month just recently and i thought sure it was an axle issue since i had just had them changed. Low and behold, it turned out to be a broken sway bar link just like yours. Simple fix that makes a world of difference.
Old 03-10-2012, 10:27 PM
bigdaddyII's Avatar
bigdaddyII
bigdaddyII is offline
Geez those look pretty bad. I have 170k on mine and they arent disconnected yet but are loose. I just cant bring myself to pay the price the parts stores are requiring for new ones.
Old 03-10-2012, 10:34 PM
boosted-fc3s
I think the moog links were like $90 for the pair and the bushings were $25 I think. Not exactly cheap.
Old 03-10-2012, 11:04 PM
NV290's Avatar
NV290
NV290 is offline
Less then $100 for the pair of new end links (Greaseable too):
2002 1500 Ram:
http://www.partsgeek.com/catalog/200..._bar_link.html
Just make sure you choose RWD or 4WD They are different.
Old 03-11-2012, 01:55 AM
Caseys-dodge's Avatar
Caseys-dodge
Caseys-dodge is offline
Dang it, I thought this thread was gonna help me figure out my rattling noise, but I took my sway bar off over a year ago and still a bunch of rattles, especially at slow speeds. I've been under that truck so many times with a rubber mallet and still have no idea.
I agree, the price that the local part stores wanted for the sway bar end links was ridiculous.
Old 03-11-2012, 07:38 PM
boosted-fc3s
Gotta be bushings or something like that. Sorry to disappoint you . But this solved my front end rattle .
Old 03-11-2012, 10:56 PM
Caseys-dodge
I wonder if my lower control arm bushings would be the cause. Mine seems to rattle more if I have light pressure on the brakes but I've taking apart the brakes many times and they are tight.
Old 03-20-2012, 11:20 PM
IABOOMER's Avatar
IABOOMER
IABOOMER is offline
This is an old thread but sounds like the problems I'm having. Did you ever get this resolved? My issue is worse during the cold months (which you don't have a problem with). I'd like to have an idea of any solution before I have this checked out.
Thanks.
Old 03-20-2012, 11:22 PM
boosted-fc3s
10 days is old? I've seen 3 or 4 year old threads get brought back from the dead.
Quick Reply: Rattling Front End Solved
