Transmission Fluid And Filter Change
Old 03-07-2012, 09:42 PM
rollin_99's Avatar
rollin_99
rollin_99 is offline
Default Transmission Fluid And Filter Change
Planing on changing the transmission fluid this weekend and would like to know if there is a preferred transmission fluid and filter? Is the OEM filter better then an aftermarket part? Anyone here running synthetic? Is there anything else i should do while i have the pan out?
Old 03-07-2012, 10:01 PM
Old_School's Avatar
Old_School
Old_School is offline
Adjust the bands... Valvoline or Mobil 1 synthetic ATF+4
Old 03-07-2012, 10:13 PM
rollin_99's Avatar
rollin_99
Is there a write up on the band adjustment. There seems to be a conflict on how many turns to back off the adjuster screw. 3 vs 4?
Old 03-07-2012, 10:59 PM
DomsDodgeDingo's Avatar
DomsDodgeDingo
DomsDodgeDingo is offline
Put some Seafoam Trans tune in right before you change the fluid and drive it around a biy
DomsDodgeDingo
Put some Seafoam Trans tune in right before you change the fluid and drive it around a bit
Old 03-08-2012, 09:18 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
talk to master tech about the band adjustment, he is a chrysler certified transmission tech for a dealer, he knows his stuff.
on fluid, use only mopar approved ATF +4, mopar, valvoline, there might be others im not aware of, although i dont think mobile1 is on that list. (if you use so mehting else you could tear up your transmission)
i would just get the filter from the dealer and be done with it.
and remember NEVER EVER EVER put anything besides mopar approved ATF+4 into a chrysler motors transmission unless you want to be replacing it in the not too distant future.
Old 03-08-2012, 02:44 PM
otgarzā's Avatar
otgarzā
otgarzā is offline
I use the castrol atf+4 but the valvoline seems to be the popular choice. And yes get the filter at the dealer. As for the bands i have the 545rfe
Old 03-09-2012, 02:26 AM
rollin_99's Avatar
rollin_99
Looks like I'm all set. I found a post by HS for the band adjustment conflict and I'm going to check all-data to be sure. Going with the Oem filter and valvoline synthetic atf +4. Thanks for the heads up on the band adjustment it's been awhile since i messed with an auto. Thanks again fellas.
Quick Reply: Transmission Fluid And Filter Change
