3rd Gen Durango 2011+ models
Key Fob locked inside
Old 03-05-2012, 10:01 PM
rmeurer's Avatar
rmeurer
rmeurer is offline
Talking Key Fob locked inside
I have a 2011 Durango Crew. In the manual it states that if the engine is off and a key fob is in the proximity of the vehicle and you use the manual door lock on the drivers side door (or any for that matter), that the vehicle will automatically unlock and the horn will chirp.
My Durango does not do that. I locked my keys in my vehicle. I've tested it and every time it's the same. the key fob is inside and the doors lock. Now I know if you do this 3 consecutive times, it will allow you to lock them in, but it shouldn't happen on the first time.
I called my dealership and they said Dodge hasn't provided a fix for this, so there is nothing they can do and I should be more careful.
Please tell me that there is an easy fix or any fix to this issue.
Old 03-06-2012, 02:26 AM
rdkind62's Avatar
rdkind62
rdkind62 is offline
Easy fix. Don't lock the door if your FOB is in it.
Old 03-06-2012, 04:31 AM
deedubb's Avatar
deedubb
deedubb is offline
Do a search please. I posted this same exact thing a few weeks back. Check here: https://dodgeforum.com/forum/3rd-gen...-possible.html
Old 03-06-2012, 08:57 AM
rmeurer's Avatar
rmeurer
rmeurer is offline
I saw your posting, but it appears the issues are different. your vehicle was running. mine is not.
Old 03-06-2012, 10:00 AM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
Rmeurer,
When you do this where is the other FOB you eventually use to get back in the vehicle?
Old 03-06-2012, 08:21 PM
rmeurer's Avatar
rmeurer
rmeurer is offline
The other fob was miles away.
Old 03-06-2012, 08:53 PM
vonbonds's Avatar
vonbonds
vonbonds is offline
Man, what a nightmare!
Old 03-07-2012, 08:57 AM
DodgeCares's Avatar
DodgeCares
I am assuming you have the passive entry system, correct?
If no one is inside the car and the FOB is in the car and no other FOB is outside the car, then if you lock the doors using the power lock switch the system should unlock the doors while chirping the horn 3 times then re-lock the doors.
When you use the FOB to lock your doors from outside the vehicle does the horn chirp? Is auto unlock selected on the EVIC?
Quick Reply: Key Fob locked inside
