Security light flashes , no start
Old 03-04-2012, 10:58 AM
MR>DODGE999's Avatar
MR>DODGE999
MR>DODGE999 is offline
Cool Security light flashes , no start
Hey everyone, need some help . I got a 2006 dodge ram 3500 5.9 diesel truck . I just replaced the engine , so the batteries have been dis-connected for five days .Security light is flashing and engine will crank , but wont start. Im confident all the wiring is correct and grounds are grounded properly . I can't hear the pump when i turn key forward either . Ive checked all the fuses . Is it not recognizing my keys ? ANy help would be appreciated .
Old 03-04-2012, 10:18 PM
horatio102's Avatar
horatio102
horatio102 is offline
On my 08, the ECM was bolted to the side of the engine. Is your 06 the same way?
If so, did you keep the ECM from your original engine, or did the new engine come with a new ECM?
To me it sounds like an immobilizer issue. I think Dodge calls it Sentry Key or some such thing. Anyway, there's a chip in the key that has to get programmed into the BIU/ECM or the truck won't start.
Might be time to drag it to the local dealer.
Old 03-05-2012, 07:12 PM
MR>DODGE999
Yes it is block mounted . ESM wont communicate with Scan tool . Towed it too the dealer . Havent heard anything yet . But i will post the result when I find out . THx for the advise .
Old 03-07-2012, 09:32 PM
Parts/Service's Avatar
Parts/Service
Parts/Service is offline
If the theft system was kicking in, the truck would start and run for a few seconds and die. Eventually after so many attempts the truck would not crank over.
Old 03-08-2012, 12:19 PM
MR>DODGE999
Missed a wire to the PCM , ( my bad )
Old 03-08-2012, 09:34 PM
MR>DODGE999
actually after talking to the mechanic at dodge , it was the main connector on the harness plug , (the big plug ) driverside of the valve cover on at the back . Two clips on the side were broken , the lever still pushed together , but didnt make a good connection . Used ziptie too hold together . works fine now .
Old 03-09-2012, 07:54 PM
horatio102's Avatar
horatio102
Well that's good. Glad it's fixed, although it's too bad you got popped for the tow and diag time.
Quick Reply: Security light flashes , no start
