gear ratio!
Old 02-28-2012, 10:28 PM
jake122288's Avatar
jake122288
jake122288 is offline
Default gear ratio!
I have a question regarding axle ratio's... So according to the faq, they came with "Ratios: 3.21 (rare), 3.55 (normal), or 3.90 (rare). " I emailed dodge with my vin, to figure out the production codes/order... and in that list says it came with 3.92 gear ratios....
So are they actually 3.9's or 3.92's? I didnt know if it was an error in the faq or an error from dodge or what.
Old 02-29-2012, 02:46 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
According to the parts manual it is 3.90. It is common for manufacturers to round off the numbers. If you want the truth just divide the number teeth of the pinion by the ring gear.
In any case .02 of front to back axles ratios difference is safe.
Old 02-29-2012, 03:26 PM
marcar1993's Avatar
marcar1993
marcar1993 is offline
It is 3.92.
Quick Reply: gear ratio!
